Good points by Ken and Ted, I wasn't worried about thread pitch as the engine mounting bolts are all going onto their own nuts but I hadn't considered this with the lower yoke pinch bolts. Are they standard 1.5mm pitch on the m10 bolts?I might have to have a rethink on the lower engine mounts.
Quote from: DomP on November 23, 2023, 08:50:50 PMGood points by Ken and Ted, I wasn't worried about thread pitch as the engine mounting bolts are all going onto their own nuts but I hadn't considered this with the lower yoke pinch bolts. Are they standard 1.5mm pitch on the m10 bolts?I might have to have a rethink on the lower engine mounts.Just been through all this. IIRC Kay fast and middletons don’t have t some of the bolts in the correct pitch and I ended up getting them from china on ebay( bottom yoke maybe) what I have found is that by grinding off the lettering , polishing up with the brush wheels and bench polisher the heads can quite easily end up with a mirror finish. https://www.ebay.co.uk/itm/354792939265?var=624112326971
Oh b@gg@r, I ordered from Middletons but thought the 14mm headed M10 bolts were metric fine so ordered some nuts on Ebay, turns out they are 1.25mm thread pitch.
Quote from: DomP on November 30, 2023, 06:26:59 PMOh b@gg@r, I ordered from Middletons but thought the 14mm headed M10 bolts were metric fine so ordered some nuts on Ebay, turns out they are 1.25mm thread pitch.You are not alone Dom in finding confusion with metric threads - it does not help that some sellers do not seem to state thread pitch plus the parts manual might mention diameter & length but naff all about pitch or head size.Many decades ago I had a simple alloy tool that was a rectagular plate with common british thread sizes marked on it (AF & BSF, BA etc). If you were not sure of a thread size you screwed your bolt in by hand to find the right siize. You could also check nut sizes by sizing a bolt then trying your nut on an identified bolt.It was a promotional tool at the garage where I worked - it came free with some red tins of fastners by a manufacturer - forget the brand name now something like Tewul ?
