So gents all help and points welcomed. settle back and i shall tell you the info:
engine: cb550k3 standard with a very mild porting job on the head, more just smoothing than porting, no polishing tho!
carbs: Keihin CR 29mm
Pod Filters
mains: 240
main jets: 120
mixture: 1 1/2 turns out
Needles: right at top position
timing: checked and rechecked (!)
floats: Factory set 14mm
ignition: boyer bransden, with mini coils
So have tried various settings but taken her back to 'out the box' carb settings.
To start her she must be on full choke and i can only get her to 1/3 choke before she dies. i cannot get idle no matter what i do.
when she is on full choke she revs right up with no trouble. when the choke is set at 1/3 when you pull the throttle the engine loses rpm/power. i know she is running lean and i have tried 118 and 122 main jets but i cannot get any kind of idle.
carbs have been bench synced and i have tried different mixtures etc but all the same or worse probs and no idle.
have tried advancing the timing on the stator plate but to now avail.
Need a bit of direction here peeps. how much bigger should i go with the main jets? am i clearly missing something?
(beer tokens for the best answers!)
