Other Stuff > Desperately Seeking!!
Im assuming at some point ill need to balance my Carbs - can anyone reccomend...
McCabe-Thiele (Ted):
It says there is no Mercury in what look like Manometer tubes - is there some sort of metal cone in the tubes that the vacuum pulls up into view to measure the flow?
Update:- Having watched the u-tube video I'm not sure what you are adjusting to balance the readings - is it the carb sliders or the air screws?
davidcumbria:
I’ve got a carbtune pro and used it on my boxer twin quite effectively. It has metal weights in the manometer tubes in place of the old mercury set up.
If I feel extravagant I will get the £259 esync tool favourably reviewed by Ralph Fernand in classic motorcycle mechanics which provides much more diagnostic capability ( worn valve etc) and accurate syncing
https://www.healtech-electronics.com/products/est/
Navigation
[0] Message Index
[*] Previous page
Go to full version
