Other Stuff > Desperately Seeking!!
500/4 mechanical advanced unit 30220-323-154
cbxman:
--- Quote from: fryerk on April 02, 2024, 02:18:36 PM ---Ive never been 100% happy with the Boyer its very voltage sensitive so I need to keep the bike on a trickle charge. Id like to go back to points to compare.
--- End quote ---
Hi have Dyna on my CB750 K1. It was very unstable and would misfire sometimes and this I understand was a common issue with these. The installation instructions specified connecting the Dyna +12v Feed onto the ignition switched 12v leads on the coils. However I found through experimentation that the 12v ignition feed that is accessible under the seat (for indicators etc. was a better place to connect. It runs without any issues now
Unsurprisingly really as the voltage spikes on the 12v coil terminal would play havoc with the Dyna.
Worth a try before you bin the Boyer.
K2-K6:
The supply to any electronic ignition could be wired direct to battery for the loaded circuit
With something like this https://www.12voltplanet.co.uk/standard-mini-make-break-relay-normally-open-no-contacts-12v-20a-with-fuse.html 12v relay incorporating it's own dedicated fuse as protection for that circuit only.
This would then only be triggered by switch on of ignition key, with fully independent direct supply to handle ignition system load autonomously.
Navigation
[0] Message Index
[*] Previous page
Go to full version
