Author Topic: how do you see sent personal messages?  (Read 319 times)
Offline beardylondon
« on: April 18, 2024, 01:12:04 PM »
ignore, I found out why
« Last Edit: April 18, 2024, 01:14:23 PM by beardylondon »
1976 CB550 K2 (USA import)
Offline Craizeehair
Re: how do you see sent personal messages?
« Reply #1 on: April 18, 2024, 02:15:39 PM »
What’s the answer, I can’t see mine either, only received messages?
« Reply #2 on: April 18, 2024, 02:27:29 PM »
If you go to Messages, there’s an Inbox and an Outbox.
2022 Tiger Sport 660
Offline Craizeehair
« Reply #3 on: April 18, 2024, 04:16:53 PM »
Ahhhh, thank you. It’s not hard for me to be baffled, much appreciated.
Not sure if anyone really uses tapatalk but I’m usually on my phone so it’s my usual way to access, any idea if there’s a way to see them using that?
« Reply #4 on: April 18, 2024, 05:02:58 PM »
Tried it once, buggered up my old dumfone so never again
« Reply #5 on: April 18, 2024, 06:30:47 PM »
Bottom menu (on an iPhone)
Then select either Inbox or Sent Messages.
Offline Craizeehair
« Reply #6 on: April 18, 2024, 06:35:51 PM »
That’s what I thought it would be but when I select sent messages it is blank?
It’s only here, as I use tapatalk elsewhere, maybe I need to do something from a laptop, a setting or something? I’ll have to keep fiddling about.
« Reply #7 on: April 18, 2024, 06:58:57 PM »
There is a checkbox that says “save sent messages”
Maybe you need to do that on a PC.
I do remember trying to make it default to “yes” but that wasn’t an option.
Offline Craizeehair
« Reply #8 on: April 18, 2024, 07:05:53 PM »
Thanks Steve, I will take a look later.
Online magpie114
    • A.M. Photoblog
« Reply #9 on: April 18, 2024, 07:29:45 PM »
I have this problem as well on IOS so I always use a desktop for messages where I've have selected the check box under Personal Messages »Change Settings to save sent messages.
I may be looking in the wrong place but cannot see this option in Tapatalk to save a copy in sent items.
Alan
Honda CB350F
Honda VFR400
Suzuki 650
Offline Craizeehair
« Reply #10 on: April 18, 2024, 07:43:06 PM »
I’ve just checked on the laptop and I can see my sent messages there but not on tapatalk on the iPhone?
Not the end of the world but it does show sent messages on other forums for some reason?
