Author Topic: CB550 Oil Filter Bolt Removal  (Read 1767 times)
Re: CB550 Oil Filter Bolt Removal
« Reply #15 on: April 24, 2024, 11:05:49 AM »
I have the standard Bahco 1/4 drive set that someone here recommended a great little set.
Bahco/SO/Blue Point group appear to have cornered the market.
« Last Edit: April 24, 2024, 11:08:28 AM by McCabe-Thiele (Ted) »
Offline Mike_Berkshire
« Reply #16 on: April 24, 2024, 03:52:18 PM »
Victory is mine! The bolt extractor sockets didnt work although a great purchase for future use. Eventually I had to opt for cold chisel and the big hammer - thank goodness for the flange under the bolt head.
« Reply #17 on: April 24, 2024, 03:57:28 PM »
Well done. Victory!
Online Johnwebley
« Reply #18 on: April 24, 2024, 03:59:22 PM »
Good for you,
The idea of the small head, is to stop it being tightened to much,
I also grease the O ring under the head to prevent it sticking/corroding
Offline Deano400
« Reply #19 on: April 24, 2024, 04:09:23 PM »
Check for the washer between the spring and the oil filter. Often stuck to the oil filter and often accidentally binned. I have 3 engines here and none of them had the washer.
BTW mine are 400s, I imagine yours has a similar washer.
« Reply #20 on: April 24, 2024, 04:30:02 PM »
Result - you can't sometimes beat brute thuggery.👍👍👍
Online Johnwebley
« Reply #21 on: April 24, 2024, 04:35:20 PM »
Yes, the 500 has them
Fit between filter and spring
« Reply #22 on: April 24, 2024, 05:05:57 PM »
Nope - no washer on the one I removed. Spring, yes. Washer, nope.
« Reply #23 on: April 24, 2024, 05:38:19 PM »
A lot of owners throw the washer out with the old filter, over the padt 3 weeks, I've sold 15 of them from my Ebay page 😂😂😂
Online davidcumbria
« Reply #24 on: April 24, 2024, 06:40:56 PM »
Well done  Mike - very satisfying to overcome such problems
David
Offline ozzybud
« Reply #25 on: April 24, 2024, 06:45:39 PM »
Great feeling. Good job
Very surprised the stud extractor did not work. Did you use the one size smaller than the one that fit and tap it on?
« Last Edit: April 24, 2024, 06:48:03 PM by ozzybud »
1976 Z50 YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
« Reply #26 on: April 24, 2024, 09:49:29 PM »
Yes and it just tore off some of the remaining metal but there was just a small nub left.
Still I’m sure they will come in useful in the future
Offline Jan B
  • Everything you can leave behind is a gain
« Reply #27 on: April 26, 2024, 10:34:00 AM »
You must be chuffed.
What replacement bolt will you be using? There are non OEM bolts with a larger hex. Less change to get mangled.
« Last Edit: April 29, 2024, 11:11:20 AM by Jan B »
CB500K1
CB750K2 [project]
BMW F800GS
« Reply #28 on: April 26, 2024, 01:37:47 PM »
You ust be chuffed.
Thanks Jan! Yes chuffed but more relieved that I got it out OK. I havent yet thought about what replacement but a good call that some have larger bolt heads. I will also need the washer that goes between the spring and oil filter. It was either never there or I threw it out with the old (ancient) oil filter I removed. I did have a dig through the bin but didnt find anything.
