Author Topic: top end gasket set recomendations  (Read 888 times)
Offline neat street
« on: May 04, 2024, 10:03:39 AM »
Hi All
not been on for a while, now have a CB500 1973 to go with the 750, and taking top end down. could anyone please recomend a top end gasket set? (hopefully complete) :-)
thank you
John
CB500 1973
CB750F 1976
KLX250 1983
Lambretta SX200
Mini Mayfair 1984
Re: top end gasket set recomendations
« Reply #1 on: May 04, 2024, 10:07:42 AM »
I can't
But most do not contain the rubber pucks,
Also the valve stem seals can be a bit iffy
Might be worth buying those separately
Offline neat street
« Reply #2 on: May 04, 2024, 10:11:12 AM »
thanks John, :-)
CB500 1973
CB750F 1976
KLX250 1983
Lambretta SX200
Mini Mayfair 1984
« Reply #3 on: May 04, 2024, 07:05:59 PM »
No matter what set you need thicker O rings at the headgasket than those in the set
Offline Mike_Berkshire
« Reply #4 on: May 04, 2024, 09:19:12 PM »
Does this apply to all gasket sets Bryan or just relating to this particular model? I will be putting the top end back together on my CB550 in the next month or 2 and it would be good know if I’m going to need to source some different O rings.
« Reply #5 on: May 04, 2024, 10:49:26 PM »
All head gaskets are now thicker than Honda original due to no asbestos used in manufacture but the suppliers still give you the original size O rings so they dont seal as well.
If you go to the US site and look up Mark Paris (Hondaman) he can sdvise on size, i dont have all my books to hand
Offline neat street
« Reply #6 on: May 05, 2024, 07:52:55 AM »
Thanks Brian, good to know and will have saved some headaches later. :-)
CB500 1973
CB750F 1976
KLX250 1983
Lambretta SX200
Mini Mayfair 1984
Offline DomP
« Reply #7 on: May 05, 2024, 08:18:22 AM »
Maybe get the block skimmed which will make the oring recess slightly shallower, that's what I did following Brian's advice after he rebored my block.  I used Vesrah gaskets from DS
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
« Reply #8 on: May 05, 2024, 08:49:58 AM »
I have a local source for most O rings
A company called Hayley Group
On a local industrial estate, the Hereford branch are really helpful,
Imperial, metric,fuel resistant etc,
And the bonus, normally a fraction of the cost of NOS,
Take a sample, and the item, like tappet cap ,they will find the size needed
« Reply #9 on: May 05, 2024, 10:23:16 AM »
It depends which gasket set you use as to the size O rings you will need. All the kits have different depth head gaskets.
Offline DomP
« Reply #10 on: May 05, 2024, 05:37:56 PM »
Now you tell me John!😄
1975 XS650B
Offline neat street
« Reply #11 on: May 06, 2024, 08:26:53 AM »
Thank you John
Great tip and advise :-)
CB500 1973
CB750F 1976
KLX250 1983
Lambretta SX200
Mini Mayfair 1984
Offline neat street
« Reply #12 on: May 06, 2024, 08:30:06 AM »
Thank you nurse Julie
any adea on the difference I should be looking for from gasket thicknes to `O ring`? or how would you work out what size would be best to use?
thank you again
CB500 1973
CB750F 1976
KLX250 1983
Lambretta SX200
Mini Mayfair 1984
« Reply #13 on: May 06, 2024, 10:10:12 PM »
Check the thickness of new gasket compared with old and the difference then added to standard o ring thickness.
1978 Honda CB550K3.
Offline neat street
« Reply #14 on: May 10, 2024, 03:25:00 PM »
thank you Johnny, the old gasket is completely damaged beyond measurement, had to scrap off, but thank you for the tip
CB500 1973
CB750F 1976
KLX250 1983
Lambretta SX200
Mini Mayfair 1984
