Author Topic: Best way to lubricate none O ring bike chains question?  (Read 474 times)
« on: May 07, 2024, 10:48:16 PM »
My chain was replaced and was ittle used when I purchased the 500 from Bryan.
I have removed the light surface rust, after cleaning I have sprayed it with some chain lubricant that I have on my shelf it's a black coloured foam type grease called "IZUMI" Racing Japan that was given to me.
I have read online about a product called Putoline Chain Wax - not cheap but it sounds a neat idea to heat it up so the lubricant fully penetrates the rollers etc.
What do members here recommend as a good lubricant?
Re: Best way to lubricate none O ring bike chains question?
« Reply #1 on: May 08, 2024, 04:53:37 AM »
Ted, take a look at www.chainmate.co.uk
This product was designed by a friend of mine to answer the question “how do I spray chainlube in my chain without getting it all over the back of my bike?”
He maintains that it’s not so much which chainlube you use as how often you use it and how effectively you apply it.
I designed and run his webshop so I know that our bikes don’t appear in his bike finder list, but it would be simple enough for him to add them.  He has adapted his products for Norton Commandos and (old) Tridents.
I don’t get anything from his sales, but he does pay hosting fees.
Steve.
2022 Tiger Sport 660
Offline Skoti
« Reply #2 on: May 08, 2024, 07:04:14 AM »
Thumbs up for the big flat tin of Putoline chain wax, I use it on my Commando.
I brush the chain off with petrol first then it dry and boil it in the tin using a camping gaz stove in my garage.
Hang up to cool off and set the wax and your good to go for 500-1000 dry weather miles.
Chainmates a clever idea, but on my F1 that runs an O ring chain I stuff a bit of cardboard box up between the main stand and wheel to catch over spray mess when applying Silkolene chain lube.
Cardboard costs nowt...
Oh, BTW is it not the norm to apply chain lube on the inner run of the chain so the oil is flung out thru the chain when in operation?
« Last Edit: May 08, 2024, 08:52:34 AM by Skoti »
Skoti
1976 Honda CB750F1
« Reply #3 on: May 08, 2024, 08:12:43 AM »
The old fashioned method was the big flat tin of grease you heated on  stove,
But several sprays,
I use Silkoline,or Bulldog BDX,
the later is also great as a freeing agents for stuck nuts and bolts,
It freed all my engine studs ,so I could get the motor out,
Applying, take the bike for a run,
Get it warm,
When you get home,
Put on centre stand, in 1st gear so the wheel turns slowly, spray onto chain and sprockets were they meet at the bottom run,
Careful of the over spray
Offline florence
« Reply #4 on: May 08, 2024, 09:16:21 AM »
And let us not forget the elegant and brilliant Scottoiler.  I have one on my bike and it works brilliantly.
Online taysidedragon
« Reply #5 on: May 08, 2024, 01:27:27 PM »
Yes, always apply lube to the inner run of chain. 👍 Lube applied to outside run of chain just gets flung off easily.
Skoti, you make me nervous using petrol to clean chain , then using naked flame on camping stove! 🤔
Offline Skoti
« Reply #6 on: May 08, 2024, 02:38:48 PM »
Aye Gareth,
the https://www.chainmate.co.uk/ appears to lube the chain on the outside.
But back to the Putoline stuff, as you say It is a bit dodgy messing around with petrol to clean your chain then boiling it up in the big lube tin using a gas stove, I try to be careful, but maybe paraffin would be safer?  What do others use?
Thanks for your concern tho.
Skoti
1976 Honda CB750F1
« Reply #7 on: May 08, 2024, 04:07:09 PM »
Paraffin is a lot less flammable than petrol. I always used Paraffin in the past, but now I ride less miles I just use aerosol chain cleaner and chain lube.
« Reply #8 on: May 09, 2024, 09:31:17 PM »
Putoline do that wax in an aerosol Ted, anti fling it’s called and sticks like buggery. I use it on the VFR, none in stock in the shed currently as I’m using up some free stuff I got with a CSK kit but I’ll be buying some more it’s ace
Any chain lube will do as long, quite rightly put, you don’t end up with it everywhere and all over the bike.
There are several tins that you warm up in a pan of hot water which you bob the chain in, mostly in the motor cross shops, it’s a staple for them.
Really good stuff and well worth the dosh mate
