Author Topic: Mike's CB550 Project  (Read 1885 times)
Offline Mike_Berkshire
Re: Mike's CB550 Project
« Reply #15 on: May 16, 2024, 05:52:31 PM »
A great tip Ted; thanks. I used the handle of our patio broom, banged 2 panel pins into it about 5mm apart, cut the heads off and dropped it down the tube. With one nail either side of the roll pin in the damper, the fork leg in the vise and the head of the broom stopping rotation I got it out no trouble. I have discovered that ancient fork oil smells not unlike sewage too. Onwards to the next challenge.
« Reply #16 on: May 16, 2024, 06:27:07 PM »
The worst oil smell I've experienced has been with car diff oil.
« Reply #17 on: May 16, 2024, 08:06:28 PM »
You wana smell the stuff that comes out of a Leyland lock up flywheel on a coach, its burn the ovies if you splash it
« Reply #18 on: May 17, 2024, 08:08:33 AM »
Fork oil is revolting. At least there was some in there!
« Reply #19 on: May 17, 2024, 07:20:00 PM »
Having recovered from the stink of old fork oil I have been doing some work on the forks. Im looking forward to polishing the aluminium lower legs but before I treat myself to that task I thought I would give the top tubes a going over. After removing the rust on the top ends of the tubes (Scotchbrite) there is some fairly heavy pitting. The pitting is where I would expect it: mostly in the headlamp ears area but also some about an inch or so beneath the lower triple tree. The lower part of the tubes is pit-free and pretty good, there were no obvious signs of oil leaking from the oil seals when I took the forks apart so Im assuming at the business end the tubes are good. Now I need to work out what to do. Im not intending for a full restoration, I want a safe, sound bike to ride when finished. Ive read other posts about getting the hard chrome specialists in Luton to rechrome the legs but I could use the £200+ on so many other things. Also, I dont know if the pitting is something they could deal with? I would be really grateful for any suggestions from those that have gone before. Thanks, Mike
« Reply #20 on: May 17, 2024, 07:35:26 PM »
Yes, pitting is something Philpots in Luton are very used to dealing with, the companies other name is Pitted Forks 😂😂😂. Why not see how they are when you've finished your restoration, you could always send them off to them over the winter to be done.
« Reply #21 on: May 17, 2024, 08:01:53 PM »
Seals will never get that far up the tubes, i can give you a "dirty" fix that will last a while if you pm me
« Reply #22 on: May 17, 2024, 09:32:15 PM »
Thanks Julie and Bryan. Bryan I will PM you.
« Reply #23 on: May 17, 2024, 09:37:12 PM »
This is the pitting:
Offline DomP
« Reply #24 on: May 17, 2024, 09:51:31 PM »
That's exactly like mine Mike, pitted below the lower triple by around an inch or so, I think Julie has a good plan there, use it now but send them off during those miserable winter months
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
« Reply #25 on: May 18, 2024, 08:14:45 AM »
De gunge the bad bits and paintwith smoothright or similar but you willhave to opeup lower yoke a bit so as not to scape paint off, the rest of the i thin will run ok but cant get close enough on pics. I replied to your pm with a fix for the seal ares if needed
« Reply #26 on: May 20, 2024, 09:12:12 PM »
Whilst I’m working on the forks I’m thinking ahead; optimistically, about putting the front end back together again. I’m going to stick with old school bearings following the comments. I’m assuming I need to remove the lower bearing cup/ race from the the stem on the lower triple tree as it will be worn. Looking at it there is a rubber washer (maybe 2?) beneath it and a shim beneath that. I guess these are removed by levering/bashing from beneath using a drift or cold chisel and then the new one needs a new shim and rubber washer(s). Does this sound like the right approach?
« Reply #27 on: May 20, 2024, 09:55:46 PM »
My BiL removed mine using one of these on my 400 it removes the bottom race without causing any damage .
Ideal if you fit a new bottom race and then need to remove it to fit a shim underneath.
I bought one for myself as it was not expensive when I was fitting a taper roller kit to my 500. https://www.ebay.co.uk/itm/403899872756
Alternatively as you described plus heat might help.
« Last Edit: May 21, 2024, 12:48:59 AM by McCabe-Thiele (Ted) »
« Reply #28 on: June 01, 2024, 09:37:59 PM »
The lower bearing etc tapped off quite easily using a blunt punch and a nylon hammer. All the valves have been lapped and replaced with new valve stem seals. The frame and swinging arm should be back from the paint shop end of next week. I’m not sure what task will be next; probably rebuilding the front end once I have the frame back with intermittent tinkering on the engine.
I have been studying the manual I have (Haynes) to ensure when it comes to putting the barrels and head back on that I am familiar as possible with the approach but I’m finding it difficult to be sure that I know what O rings go where. Some of the instructions in the manual are vague. I have had a look in Aladdin’s Cave for something more definitive like an exploded diagram or something but so far have not been able to find anything. Can anyone point me in the direction of any material or instructions that would help with this?
« Reply #29 on: June 01, 2024, 10:14:00 PM »
Have a look at the parts book in alladins cave, also the proper Honda manual
