Author Topic: Brake pads recommends  (Read 644 times)
Offline beardylondon
« on: May 22, 2024, 02:04:53 PM »
Hi All,
I need some brake pads for my 1976 CB550, just OEM quality is fine, I don't need anything fancy, any recommends?
DS ones look ok?
https://www.davidsilverspares.co.uk/CB550K-1976-USA/part_70735/
1976 CB550 K2 (USA import)
Online deltarider
Re: Brake pads recommends
« Reply #1 on: May 22, 2024, 03:37:17 PM »
Those are EBC FA13. I had them decades ago and replaced them soon thereafter (pic). They sqeal like a pig. Also you need to remove paint from the sides and chamfer them somewhat.
I now have SBS Street Organic 501HF. Mwah... ok, but nothing special.
« Last Edit: May 22, 2024, 03:40:05 PM by deltarider »
« Reply #2 on: May 22, 2024, 05:57:02 PM »
I found that the DS ones in my 400 soon started to sqeal - I replaced them with a standard road use Brembo Carbon/Ceramic pads that I tappered on the leading edges - back in 2022 Brembo's were £34 delivered.
I found the Brembo pads had a nice progressive feel to them.  I now have them on my 500 as well.
Like the choice of tyres I think it's quite subjective and dependent on riding style - nothing wrong with the DS ones they function OK - no doubt the noise can be fixed with some tapering of the leading edge & disc face cleaning.
Offline Skoti
« Reply #4 on: May 22, 2024, 06:26:29 PM »
Those EBC v-series pads are squeal free for me.
But more expensive than the basic FA13 organic type.
EBC FA13V semi sintered pads.
https://4into1.com/ebc-v-series-semi-sintered-front-brake-pads-fa13v-honda-cb350-cb750/
« Last Edit: May 22, 2024, 08:18:26 PM by Skoti »
Skoti
1976 Honda CB750F1
« Reply #5 on: May 22, 2024, 09:48:29 PM »
Thanks, is the v series the one I have linked to above?
Offline Skoti
« Reply #6 on: May 23, 2024, 06:23:38 AM »
No, you've linked to the cheaper FA13 organic pads.
FA13V pads are semi sintered.
Skoti
1976 Honda CB750F1
« Reply #7 on: May 23, 2024, 06:44:13 AM »
Thanks, I just read up on them, they seem great, but £39 for a set of pads seems bit steep for me!
Maybe I’ll get these Sbs ones
https://www.ebay.co.uk/itm/335207027324?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=VCIbScCKRga&sssrc=4429486&ssuid=wmWanCu3SsS&var=&widget_ver=artemis&media=COPY
« Last Edit: May 23, 2024, 06:47:55 AM by beardylondon »
Offline Skoti
« Reply #8 on: May 23, 2024, 06:58:35 AM »
Good luck with the SBS ones, they squealed when I used them.
They're now in a box under my bench with other bits and bobs labelled shite...
Skoti
1976 Honda CB750F1
« Reply #9 on: May 23, 2024, 09:40:35 AM »
ha ha, fair enough
Online deltarider
« Reply #10 on: May 23, 2024, 12:18:13 PM »
I know they're a tight fit. Have you tried removing paint from the sides?
« Reply #11 on: May 24, 2024, 04:53:31 PM »
I went with the FA13V ones in the end, as I found a cheaper supplier!
Thanks for your help!
