The DS rim kit is a standard unit for standard 7" inch headlamp units.
You can fit a sealed beam, LED, unit or glass with metal reflector unit. On none sealed beam types there is a metal type lug to match the glass ones on a sealed beam type unit
Might be worth checking that the 500/550 units all use the same headlamp bowl.
