I put mine above the lower triple tree, not sure if it’s correct but fits perfectly.
Quote from: SteveW on February 01, 2025, 10:39:27 AMI put mine above the lower triple tree, not sure if it’s correct but fits perfectly.Are you above or below the tank mounting rubber?
Does this help, it's out of the 500/550 manual?
Mine is like in the diagram, main loom passes under the tank rubber then goes back up going in between the top and botton steering yokes if that the right terminolgy. IIRC I added a 400 type wiring clip that goes under the left tank rubber, can't be sure there was not one there before.
Definitely goes quite a bit below the tank mount on the LHS. And then straight to the headlamp shell. Not a great design as the flex turning the bars put stress. Only bit that needed work on my K0 as the sleeving had become hard (Colorado weather) and cracked. The later 550s with the clip and bolt is better, but a 500 loom may not be long enough. This is the best I can find.
