Try our re-instated info resource - "Aladdin's Cave" (Main menu)- sorry it's taken so long to fix
Isn't there a spring loaded ball bearing that acts as a positive stop?
If there are no daytime lights or bulbs fitted is this idea still valid Micky?Would your idea lead to a dull glow somewhere else in a light unit?The mystery of electrics know no bounds.😁
Quote from: McCabe-Thiele (Ted) on November 24, 2026, 10:31:33 AMIf there are no daytime lights or bulbs fitted is this idea still valid Micky?Would your idea lead to a dull glow somewhere else in a light unit?The mystery of electrics know no bounds.😁 Good point Ted. I have not found out yet whether it is a UK or USA spec model, but, the fact that it works ok until the switch is moved to its full extent definitely points to a switch problem. Depending on the market, UK/USA, there is the possibilty of current leaking to the dipswitch, or headlamp flasher. If it's a USA model, is the dipped headlamp on all the time? If so, then maybe it's difficult to see if current is being fed to perhaps the main beam circuit. Would definitely go for a replacement switch
Is this it???
Quote from: TrickyMicky on November 24, 2026, 01:52:06 PMIs this it???Yes - but it's £48. I don't need it that badly lol.
I'll have a look in my box of switchgear bits Neil and see if I have a spare plastic box for the 550F. I have loads of bits lying around, it's finding them when I want them that's the hard part. Try this. Disconnect the grey wire in the headlight and the orange and light blue wires. Jump a wire between the grey and the light blue wires in the loom, do the indicators now flash? Same for the orange. If they flash ok the switch is the problem. If they just stay solid like before the problem lies elsewhere.
Have you tried testing the voltage variation from the switch output in the two switch positions with the corresponding headlamp connection, Blue or Orange disconnected?
