I'd get a few miles in and see if things need to be altered, a diffrent steering stem / tripple tree arrangement could then be looked at or longer forks. In the 70's there were extenders that screwed into the top of the forks to make them longer but I think that would be pants as a long term solution, might be worth trying if a cheap set were to be found to see if they helped if the geometry proved problematical. I'd try it as is as often forseen problems fail to materialise - I have had all manner of advise about the way my 500/4 sidecar wouldn't handle at all well, but I like the thing as it is and havn't even re attatched the steering damper when it broke a mounting.
I wish you would stop remining me of all the problems i had mate
