Author Topic: resin in tank falling apart  (Read 7666 times)
Offline billy192
    • Shermonkel
« on: December 31, 2013, 03:28:58 PM »
Just picked up a tank and has been lined with what looks like resin. how can i strip this out please?
Billy
Billy
Re: resin in tank falling apart
« Reply #1 on: December 31, 2013, 03:34:42 PM »
If its an older repair try petrol as the ethanol in todays mix seems to attack all the old style repairs!!!!(and fibreglass tanks)
« Reply #2 on: December 31, 2013, 03:41:34 PM »
Someone has put resin in the tank for a reason. The last tank i had cleaned due to rust was soda blasted, with great result. Don't know if there is any chemical on the market that can shift resin or what ever it is.
Online AshimotoK0
« Reply #3 on: December 31, 2013, 05:02:00 PM »
I have had electronics devices for my business potted in epoxy resin de-potted chemically but its pretty nasty stuff. Can find out for you though if you like. May have been Tetrahdrofuran (THF) I think.
Cheers AshD
Offline steff750
  • THE POWER OF DREAMS
« Reply #4 on: December 31, 2013, 05:50:40 PM »
 ;)  yes Bryan is right just keep using the the tank the ethanol will destroy that and any fibre glass tanks, the EU has given the go ahead for more ethanol to be added next year happy days to come I think lol ,last year a guy showed me some stuff he pulled out a petrol tank he was working on that had been lined with resin it looked like brown sugar and it made a real mess of the fuel system
 only the weekend I was pulling sheets of the stuff  out of my sidecar tank it was petseal in my case sealed it back in the eighties on top of rust hopefully my tank wont leak anytime soon I'm just waiting for the blocked carb jets now  ::)
« Last Edit: January 01, 2014, 11:00:28 AM by steff750 »
Offline kettle738
« Reply #5 on: December 31, 2013, 06:35:00 PM »
Go here.    http://www.tankcareproducts.co.uk/      Scroll right down to sealant removers.
I have used this stuff to get failing tank sealer out of two tanks.........neither of them needed sealing in the first place.
Tank sealer is ghastly stuff, to be used as a last resort and only if it's really needed.
Mick...........kettle738
Offline Seamus
« Reply #6 on: January 02, 2014, 05:01:06 PM »
If the ethanol in the petrol is breaking down the sealant, them meths would do the job, basically, this is ethanol with 5% methanol added to stop folk drinking it and to avoid the alcohol duty.
THF is pretty nasty and may now be a banned substance (possible carcinogen).
Offline billy192
    • Shermonkel
« Reply #7 on: January 12, 2014, 05:09:28 PM »
so far I have tried petrol and then Acetone noting. i would leave with just petrol and use but the liner is about 1 inch thick at the bottom and it keeps stopping the fuel exiting. i have ordered some MEK (read on the other forum this will shift anyrhing) fingers crossed.
so far spent £60 may have got another tank for that  ;D
Billy
Billy
Offline RGP750
« Reply #8 on: January 13, 2014, 09:13:44 AM »
I have just re done a 1959 BSA tank, I sealed it with petseal back in 1985 and the ethenol has broken it down and it has sprung a small leak.
I have used a product called Slosh, recommended by VMCC members.
I also got a tin of cleaner that removed the petseal very successfully.
I'm waiting to get the tank painted before i fill with petrol and test for ethenol resistance but only time will tell if it's as good as people say.
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
ka-ja
  • Guest
« Reply #9 on: January 13, 2014, 10:58:42 AM »
Hi,
     MEK is a solvent type cleaner for preparing industrial plastic pipe for "glueing" fittings on, both the glue and MEK dissolve the plastic surface, which makes it a very efficient cleaner of most things, including paint brushes, extreme care should be taken not to get any onto your person as it is also a powerful degreaser, if MEK won't shift it, I don't know what will, Just bear in mind it is an industrial product and treat accordingly.----Ken
Offline billy192
    • Shermonkel
« Reply #10 on: January 13, 2014, 04:29:49 PM »
RGP750,
 i have sealed my other 3 bikes with POR 50 and after 3 years they are holding great happy just to get this crud out.
Ken,
yes my heavy duty gloves and respirator will be on. i will let you know how it fairs
Billy
Billy
Offline billy192
    • Shermonkel
« Reply #11 on: January 15, 2014, 05:00:22 PM »
well after 48 hrs it looks like its breaking down. now to make a jig to turn it slowly with some nuts and bolts to make a first class job
Billy
Billy
Offline billy192
    • Shermonkel
« Reply #12 on: January 19, 2014, 04:19:11 PM »
well I have built a tank shaker  :o
 http://youtu.be/rmYs1ALYIFU
Billy
Billy
Offline mick
« Reply #13 on: January 19, 2014, 06:15:33 PM »
Nice one Billy  8) cheers Mick
Offline Green1
« Reply #14 on: January 19, 2014, 06:23:11 PM »
I thought you were going to turn it slowly that made me dizzy
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
