Author Topic: airbox assembly k3  (Read 3463 times)
Re: airbox assembly k3
« Reply #15 on: January 08, 2014, 09:06:31 AM »
Piki, in the last picture. Your breather element/condensation trap or what ever other people call it,  isn't it up side down?. Nice clean bike.
Offline Piki
« Reply #16 on: January 08, 2014, 11:32:59 AM »
Hi trigger,  it is in the correct position!!!
Subido en subir imagenes
MIKE550/4
« Reply #17 on: January 08, 2014, 12:14:32 PM »
Yeah that looks right, next part goes in upside down with spout pointing up
thanks for the photos
MIKE550/4
« Reply #18 on: January 08, 2014, 07:17:04 PM »
So after lots of input think I am there just need correct 18mm washer ;D
if this is wrong I am fitting pods  ;D
« Last Edit: January 08, 2014, 09:10:56 PM by MIKE550/4 »
MIKE550/4
« Reply #19 on: January 08, 2014, 08:01:20 PM »
its where the washer is now just wrong size fitted
18mm needed ;)
« Last Edit: January 08, 2014, 09:11:36 PM by MIKE550/4 »
Offline Piki
« Reply #20 on: January 08, 2014, 08:34:37 PM »
Thank you Oddjob I think that you are fine and I  will replace it the weekend. Very good job Mike!!!
Thank you and sorry for my English.
MIKE550/4
« Reply #21 on: January 08, 2014, 09:12:47 PM »
thanks piki.... long way to go and as you see a novice..... but I am learning
Offline MikeM
« Reply #22 on: February 23, 2014, 07:16:21 PM »
well I gave fitting the carbs a go, chamber and air filter box..... do hope this is right as I don't fancy doing it again... was not easy
before pic
« Last Edit: February 23, 2014, 07:44:17 PM by MikeM »
« Reply #23 on: February 23, 2014, 07:23:20 PM »
Looking good Mike.
Offline mickwinf
« Reply #24 on: February 23, 2014, 09:01:58 PM »
yes nice job!
« Reply #25 on: February 23, 2014, 09:03:47 PM »
Agreed carbs look great
Bitsa
