Author Topic: fork drain screw bolt sheared  (Read 12559 times)
Offline MikeM
« on: March 13, 2014, 06:53:49 PM »
how would i go about sorting this, sheared off and bolt is just below being flush ( 1mm ish under being level )
not a big bolt length wise 10mm, I would say 8-9mm in the fork, need some advice to  fix
« Last Edit: March 13, 2014, 07:11:10 PM by MikeM »
Re: fork drain screw bolt sheared
« Reply #1 on: March 13, 2014, 07:18:31 PM »
Spark Erosion if you can't drill out.
Cheers ... AshD
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: March 13, 2014, 07:45:52 PM »
It will drill out with a small enough bit.
'Then' and 'than' are completely different words and have completely different meanings. Same with 'of' and 'have'. Set and sit. There, their and they're. Set/sit. Bought/brought FFS. Bloody Americans.
Les Ross. Certified by a Professional
ka-ja
  • Guest
« Reply #3 on: March 13, 2014, 08:19:57 PM »
Hi,
   whatever you do strip the unit first, wouldn't be the first time I have had a broken screw turn itself right in when being drilled, the heat from drilling coupled with the turning action of the drillbit---ken
Offline MikeM
« Reply #4 on: March 13, 2014, 08:30:27 PM »
strip down the fork do you mean, ie get the seals out
does that mean I have to take off virtually front of bike to fix this ?
  • 1977 CB550F2
« Reply #5 on: March 13, 2014, 08:58:05 PM »
Try a left handed drill bit if you can find one.
Offline MikeM
« Reply #6 on: March 13, 2014, 09:03:08 PM »
cant get my head round this why use a left hand drill bit
ken are you saying if I drill it will purely tighten the bolt and possibly ruin the case of fork?
  • 1977 CB550F2
« Reply #7 on: March 13, 2014, 09:14:31 PM »
A left handed drill bit will try to unscrew the bolt while you drill, obviously you will need to use a reversable drill as well.
Offline MikeM
« Reply #8 on: March 13, 2014, 09:43:14 PM »
my drill is cheap n cheerful, one way only, I do know the bolt is not seized
pic
  • 1977 CB550F2
« Reply #9 on: March 13, 2014, 09:44:42 PM »
Put a fine drill down it and screw in a self tapper.
Or tap it around with a fine punch.
Hit it with an impact driver with a slotted bit on it.
« Last Edit: March 13, 2014, 09:55:19 PM by LesterPiglet »
Offline Norniron
1977 400 cafe
1972 500/4
2013 triumph STR675
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #11 on: March 14, 2014, 03:58:31 AM »
Mike... a huge pain in the arse but I'd be going with Norniron. £15....  versus the pain of stripping... or worse knackering the fork. And you'll have a tool that you can reuse. (these bits are brittle tho'... and can snap, take care)
Any they too need a left hand twist... as mentioned, to avoid screwing the damaged bolt in further.
You say the bolt is not seized.. and for this reason I personally would stay away from any RH (conventional) drilling which would twist it in further...
Whilst you're waiting for delivery soak the thread with a penetrating spray, WD40 etc etc.
ka-ja
  • Guest
« Reply #12 on: March 14, 2014, 09:07:41 AM »
Hi,
    I recommended to strip the forks for three reasons, the "drain" may be tapped all the way through the fork leg, it is far easier to drill verically down and be accurate as opposed to trying to drill horizontally, also, any contamination can be clean out easily. No need to completely strip, just remove the wheel and offending fork leg---ken
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #13 on: March 14, 2014, 10:06:04 AM »
... ah, understand now Ken, thought you previously meant to literally strip the fork to component parts. "Remove" the  single fork!!
Yup, so much easier, esp if you have a drill press.
Offline MikeM
« Reply #14 on: March 14, 2014, 10:44:39 AM »
I might try the left handed drill bit first and not go all  the way through, it might pull it out as i am drilling ?
if not i wil take it part again
