Author Topic: Starter clutch  (Read 1573 times)
Offline sand5858
Starter clutch
« on: September 14, 2014, 08:33:31 AM »
Hello there.
Is there anyone here who has tried to change the starter clutch on a CB750
I think that the Phillips screws that hold the hub in the clutch is very difficult to loosen.
Afterwards, the flywheel is mounted on the crankshaft and tighten with torque and I think this is also a challenge - something to have a friend on the motorcycle while I mount the flywheel.
All proposals received.
Regards
Tony
Re: Starter clutch
« Reply #1 on: September 14, 2014, 01:53:19 PM »
Impact driver for the screws and you will be suprised how easy it is to do up the bolt
bike-pusher
  • Guest
Re: Starter clutch
« Reply #2 on: September 14, 2014, 03:48:13 PM »
Is this a job that can done with the engine in the frame?  And if so, what needs removing to get at the clutch?
Re: Starter clutch
« Reply #3 on: September 14, 2014, 06:00:31 PM »
750 starter clutch is on the back of the generator Rotor so side cover off, undo bolt('Kin tight), use proper screw in puller to remove rotor---replace all necessary bits and reassemble
Re: Starter clutch
« Reply #4 on: September 14, 2014, 06:24:46 PM »
Spot on Bryan not really a hard job too do
Bitsa
Offline steff750
  • THE POWER OF DREAMS
Re: Starter clutch
« Reply #5 on: September 14, 2014, 07:17:50 PM »
Quote
if you are referring to the screws on back of alternator  there is no need to remove them you will be ok with them in place
Offline sand5858
Re: Starter clutch
« Reply #6 on: September 15, 2014, 06:23:11 AM »
Hello, All.
Many thanks for your advice, I will try to change the rollers on the starter without removing the screws behind the generator.
thank you
Tony  8)
Re: Starter clutch
« Reply #7 on: September 15, 2014, 06:30:34 AM »
Cange rollers, springs and spring caps all at the same time mate, I think DSS does them as a "KIT"
Offline sand5858
Re: Starter clutch
« Reply #8 on: September 15, 2014, 08:54:18 AM »
Hi Bryan.
Thank's but i have already buy'ed a starter kit. Now I just need to synchronize carburetors  4 cables on my Sandcast it is the last missing.
Thank you
Tony
