Author Topic: XADO Revitalizant EX 120???  (Read 2408 times)
Offline mihai.i
« on: November 18, 2014, 06:06:16 PM »
Hi guys!
I just saw on local forum in Romania a product called XADO Revitalizant EX 120, that they say is really good for your engine  :-\, restores worn surface of engine cylinders, eliminates microcracks and scratches, increases and levels compression in cylinders and other stuff like this...
quote
Restores worn surface of engine cylinders, eliminates microcracks and scratches
Increases and levels compression in cylinders
Protects friction surfaces against wear
Reduces fuel consumption considerably
Restores engine capacity up to factory values
Increases service life of an engine by 3 times
Decreases the level of toxic components in exhaust gases
Decreases noise and vibration level
More details here: http://xado.us/revitalizants/ex120/revitalizant-ex120-motor-equipment
What is about this product?
Do you even hear of it?
Honda Cb550k 1978
Re: XADO Revitalizant EX 120???
« Reply #1 on: November 18, 2014, 06:34:55 PM »
Its a scam. Avoid.
« Reply #2 on: November 18, 2014, 06:44:14 PM »
Never believe everything you read. "Restores engine up to factory values" What the hell does that mean and "Restores worn surface of engine  cylinders". well, that is me out of business then. :'( :'( :'( :'(
Hold on i cross hatch the cylinders and this stuff is going to correct that Hahahaha
« Last Edit: November 18, 2014, 06:48:07 PM by Trigger »
« Reply #3 on: November 18, 2014, 06:46:43 PM »
Trig
Must be an ali welder inside the tin yeah right
Remember oil stop?never stopped jack
Bitsa
« Reply #4 on: November 18, 2014, 06:52:35 PM »
Bitsa, i have ordered 200 tubes and a new armchair but, i think i will get some funny looks when i hand over the bill ;D
« Reply #5 on: November 18, 2014, 06:53:34 PM »
 ;D ;D ;D ;D ;D
Brill Mate
Bitsa
Offline matthewmosse
« Reply #6 on: November 18, 2014, 07:40:00 PM »
Snake oil. It is claiming the inpossible therefore probably delivers nothing, might even do harm. To live up to its claims it would need to weld steel to extreme accurate tolerance, alloy, ditto and know where to and not to stick. Suppose it got confused and welded the oil restrictors completely shut and oil starved the top end.
« Reply #7 on: November 19, 2014, 10:26:14 PM »
What's in the tin? a new engine?
Offline Lynx
« Reply #8 on: November 26, 2014, 09:30:56 AM »
It@s probably just like that STP stuff. Just thickens the oil. Of course you could just put 20w50 in.
Yamaha RD500LC
Triumph Speed Triple RS.
Previous bikes include
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Offline hairygit
« Reply #9 on: November 26, 2014, 09:40:10 AM »
If it's like that STP oil treatment, your engine will seem better, but you won't be getting far, ruins wet clutches, slip like crazy! A mate put some in a 400/4 many years ago, and even changing the oil and new clutch plates it still happened. In the end he had to strip the engine and wash the cases and all internals in parrafin before the problem was solved. :o
« Reply #10 on: November 26, 2014, 01:40:18 PM »
Got a tin of wynns if any body wants it
CRAP STUFF STOPS OIL LEAKS IN YER DREAMS
Bitsa
Offline RGP750
« Reply #11 on: November 26, 2014, 05:01:14 PM »
Hey you didn't get that to put into number 2 did you  ;D ;D ;D (oops! banter)
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
