Author Topic: Oil not flowing to engine  (Read 2813 times)
Offline harrycb750f1
« on: November 19, 2014, 09:03:17 PM »
I'm trying to get my crashed cb750 f1 back on the road but after changing the generator cover as it was cracked, I went fill it up with oil and it didn't flow into the engine. I checked the 2 pipes from the oil tank were clear and also checked the oil filter.
Does anyone have any idea what it could be or I could test/check?
Re: Oil not flowing to engine
« Reply #1 on: November 19, 2014, 09:14:07 PM »
Is the oil pump working?
« Reply #2 on: November 19, 2014, 10:10:36 PM »
The engine is a dry sump design, the pump is a two stage type that sucks the oil out of the sump in one part and puts it into the oil tank.
The second part of the pump takes its' supply FROM the oil tank and pumps it round the engine, just putiing oil into the tank will not flow into the engine until the oil pump is running (when you start the engine) at that point you should see the oil level initially start to drop in the tank as it passes into the engine.
As Trigger says, are you ok that the oil pump is going? It's accessed through the sump pan underneath the engine, If you've not worked on this and it was previously ok then you should be safe to start it if the level is high enough in the oil tank to make sure it has a good supply.
BUT worth turning it over first with the spark plugs removed and watching the oil light to make sure it gets pressure first before refitting the plugs and running it.
Let us know how you get on.
« Reply #3 on: November 21, 2014, 02:03:08 PM »
I tried turning the engine over with the spark plugs out but the oil still didn't pass through. So I think I should look deeper into the pump to see what happening. Cheers for the advice, a lot of help.
« Reply #4 on: November 21, 2014, 02:32:15 PM »
 did / does the oil pressure light stay on ?? or go out when you spin the motor ??
« Reply #5 on: November 21, 2014, 02:49:07 PM »
if i remember right, it stayed on
Online mick
« Reply #6 on: November 21, 2014, 03:21:23 PM »
I had the same thing on a rebuilt engine I didn't prime the pump and it wouldn't circulate oil ,
I had to take the pump off and fill it with oil and put it back on and it worked ok after that   ;) cheers Mick.
Offline Seamus
« Reply #7 on: November 21, 2014, 04:48:02 PM »
You can always remove the stopper valve cover,(2 bolts)  let valve move slightly till oil flows, then retighten. Bleeds the pump through. Worked on a couple of bikes for me.  Easier than removing the pump.
« Reply #8 on: November 21, 2014, 04:53:53 PM »
This link may help you get your head round the oil circuit / pump...
http://cb750k2.honda4.nl/lubrication-system/lubrication-system.html
« Reply #9 on: November 21, 2014, 06:48:20 PM »
I have to say guys I have never primed a pump ever.The last bike I have just finished sat for 2 years and oil light went out in seconds after starting.What I have done to help which I dont know if it helps was to lay her over and fill the main gallery with oil.Cant think of any thing else
Bitsa
« Reply #10 on: November 21, 2014, 09:10:56 PM »
Perfect, I'll give it ago and post how it goes
« Reply #11 on: November 22, 2014, 08:28:17 AM »
Harry
Dont run her for long if the oil light does not go off after 10 secs STOP
Bitsa
« Reply #12 on: November 22, 2014, 08:55:09 AM »
If I remember right when I first ran my F1 i put the bulk of the oil in the oil tank and the rest in the engine through the rockers, even so it took quite some time for the pump to take suction, plugs out until the oil light went out.
Offline steff750
  • THE POWER OF DREAMS
« Reply #13 on: November 22, 2014, 10:27:06 AM »
 ;) i think its time too bite the bullet put the plugs in and fire it up if there is any damage or wear you will hear it just keep the revs down till the oil light goes out, if it still don't go out the engine is shagged anyways, no lose no gain, if it was fine before then its no worries, tip a load of oil in the camshaft just to give it a bit of lube if the oil light is still on after a minute or two , its time for a tear down .
some of my bikes don't get fired up for weeks,it surprises me how long it takes for the oil lights to go off on some of them
 these bikes just ain't new anymore  ;)
« Last Edit: November 23, 2014, 09:54:08 PM by steff750 »
