Author Topic: swing arm grease nipples  (Read 4928 times)
Offline antonypo
  • wheres the breaks on these cb 750's !
« on: January 12, 2015, 01:15:55 PM »
As I have rebuilt the swing arm, changed bearings and powder coat, renewed dust seals and caps etc, I bought two replacement grease nipples incase of ware and blockages etc.
However in my ignorance I assumed these screwed in but as the picture shows there are no threads.
How do I get the old ones out and fit new ones without a thread?
k4 usa cb 750
Antony
Re: swing arm grease nipples
« Reply #1 on: January 12, 2015, 01:18:23 PM »
They just press in ;)
Offline antonypo
« Reply #2 on: January 12, 2015, 01:55:35 PM »
Assuming they create pressure how do they stay in?
Do i just pull the old ones out?
Antony
« Reply #3 on: January 12, 2015, 02:58:10 PM »
Anthony
The last set I got from CSMNL did not fit too small had to use the old ones so be careful getting them out
Bitsa
Offline Green1
« Reply #4 on: January 12, 2015, 03:05:51 PM »
I just taped mine in with a rubber mallet.
Pull them with a pair of mole grips they come out easy enough.
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
« Reply #5 on: January 12, 2015, 04:20:00 PM »
when fitting ONLY tap on the flange --not the end as it tends to flatten them and they dont work.
Asimple drift with a relatively close fitting hole drilled in it works.
To remove use mole grips.
As said a lot of people(Me included) drill and tap 6mm and fit a standard threaded one
Offline Green1
« Reply #6 on: January 12, 2015, 05:16:29 PM »
I suppose I should have added the mallet I used is incredibly soft I think it was a pound shop reject.
Mick
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
« Reply #7 on: January 12, 2015, 05:28:55 PM »
Mick
Well. get a good heavy one and whack yourself in the head ;D
Offline Green1
« Reply #8 on: January 12, 2015, 05:35:21 PM »
Bit harsh Trig even for you. :P
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
« Reply #9 on: January 12, 2015, 05:38:23 PM »
I was thinking pickaxe first  ;D ;D ;D
Offline antonypo
« Reply #10 on: January 12, 2015, 05:43:30 PM »
Once again thank's for the advice - job done. One nipple didn't work so glad I checked. The other was fine so left alone.
Swing arm now on and SLOWLY but surely getting there.
I have to go backwards tomorrow a little bit. I have not fitted the bolts to the steering/ yolk. I can't find any reference to torque settings in the haynes.
Any ideas where to look on the tinternet?
Antony
Offline Green1
« Reply #11 on: January 12, 2015, 06:04:53 PM »
Don't forget to put the washers in the yolk to prevent them from cracking.No:9
http://www.cmsnl.com/honda-cb750-four-k4-usa_model482/partslist/F++03.html#results
Mick
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
Offline antonypo
« Reply #12 on: January 12, 2015, 07:44:29 PM »
yes thanks for the advise i have all new replacement parts - but no torque settings !!
Antony
« Reply #13 on: January 12, 2015, 07:49:23 PM »
Anthony
I do all bolts up to resistance and then a quick nip especially with 6mm bolts and so far I have had no problems.On the front end the 8mm bolts its them that take the humph not the 6s
I am sure the experts will coment real soon
Bitsa
Offline ka-ja
  • ken
  • yoshi 460
« Reply #14 on: January 12, 2015, 08:30:29 PM »
Hi,
   No comment Bitsa, after a lifetime using spanners to earn a living, the only nuts I torque are the cylinder head bolts----Ken
nice bike,nothing in the bank
