Author Topic: What happened here?  (Read 2722 times)
Offline JustcallmeMrT
What happened here?
« on: January 18, 2015, 11:38:35 AM »
What is this and how do I fix it?
Looks to me like dried up grease and a bunch of rust.  Should I be concerned about the bearings?  Can I polish up that  spacer in the second pic or is a replacement required?
Thanks!
Re: What happened here?
« Reply #1 on: January 18, 2015, 12:04:04 PM »
It is a front wheel hub. You need to remove the bearing retainer (special tool need). Then remove the bearings. Not sure about the collar as it is dirt.
« Reply #2 on: January 18, 2015, 12:12:28 PM »
The bearings still seem smooth and no play, so was hoping to avoid removing and replacing.  Would you recommend doing it as a matter of course while its all apart, or am I safe to leave it?
« Reply #3 on: January 18, 2015, 12:13:12 PM »
Thanks for the heads up on the hub.
« Reply #4 on: January 18, 2015, 12:30:13 PM »
A nice surprise to find... glad I have 2 spares!
« Reply #5 on: January 18, 2015, 01:04:48 PM »
On your first photo that's when a PO try-ed to remove the retainer with a screwdriver or chisel bodge it.If the bearings are A OK just clean it up and fit new retainer with the proper tool.
Bitsa
Offline MikeM
« Reply #6 on: January 18, 2015, 02:25:38 PM »
i changed mine anyway, they are peanuts to buy really, the retainer was a pain to get out on mine, bike had not moved in years
you may as well change the bearings for all the money they cost
« Last Edit: January 18, 2015, 05:21:09 PM by MikeM »
« Reply #7 on: January 18, 2015, 02:32:39 PM »
Bitsa
Is the retaining ring removal tool the same for front and rear?
« Reply #8 on: January 18, 2015, 02:38:25 PM »
On bearing retainer .. remove seal, drill out any 'staking' ... tap the bruised bit of the alloy  retainer with a hammer square punch etc. to try to recover the slot shape  to original as much as possible. Use my tip here ( bottom photo is of a 750K0 front hub which has similar retainer) BOTTOM PHOTO IN POST.
Agree..replace bearings they cost very little and easy to remove/replace ... it's the retainer that is difficult without the correct tool.
http://www.sohc.co.uk/index.php/topic,7684.0.html
« Reply #9 on: January 18, 2015, 02:45:49 PM »
most of the corrosion in the wheel bearings is cause by jet washers forcing dirt and water into the bearing,
when using a jet washer,try not to spray the shaft and seal to much,
« Reply #10 on: January 18, 2015, 03:26:07 PM »
It is better to replace the wheel bearing. They are cheap but, do not use the Cheap, cheap Chinese ones.
« Reply #11 on: January 18, 2015, 04:10:07 PM »
Any recommendations?  I saw Andy Cepok on ebay out of germany does a kit for the front including retaining ring and seal.
« Reply #12 on: January 18, 2015, 04:12:13 PM »
Take your old bearings to your local bearing shop and they will match them. The front are the same size but, the rear has two different sizes.
