Author Topic: Brake calipers  (Read 6153 times)
Re: Brake calipers
« Reply #30 on: June 05, 2015, 08:03:21 PM »
Are the spring on the callipers all the same, can they be replaced with other type.
Although they are relatively cheap, with Vat and p&p still over £10 for 2 springs...
El__burro
 if your stuck,don't use the spring,it was a common mod in the '70's,in case your worried,I haven't fitted/used those springs since then
Offline El__burro
Re: Brake calipers
« Reply #31 on: June 05, 2015, 08:41:15 PM »
So, your suggestion is don't use them. Will it effect the functionality?
Re: Brake calipers
« Reply #32 on: June 05, 2015, 10:36:00 PM »
 yes,no problems,still use the adjusting screws,from about 1978 till 2012 I used without spring,and single disc,since then,I have
twin discs,again no springs,they work a treat
Offline El__burro
Re: Brake calipers
« Reply #33 on: June 05, 2015, 10:49:01 PM »
aah, the adjusting screw... is that anything common to find?
thanks
el__burro
Re: Brake calipers
« Reply #34 on: June 05, 2015, 10:56:32 PM »
thanks
el__burro
 have a look at this pic,it should show it
Offline ginger_jim
  • Anyone for a Guinness?
Re: Brake calipers
« Reply #35 on: June 06, 2015, 02:16:06 PM »
I've always found connecting the calipers to a master cylinder and pumping does the trick.  Isnt this the same caliper?
http://www.ebay.co.uk/itm/Cb750-K3-K4-K5-Brake-Caliper-/141680943727?pt=LH_DefaultDomain_3&hash=item20fcd7a26f
Interesting technique however! :o
Offline El__burro
Brake calipers
« Reply #36 on: June 09, 2015, 10:40:23 AM »
that was sorted with a grease gun.
if only id find out before screwing the first 2 callipers.
thanks ginger_jim, your technique would have also worked greatly.
P.S. is it necessary replacing the rubber washer in the piston slot?
regards
el__burro
« Last Edit: June 09, 2015, 10:42:34 AM by El__burro »
Re: Brake calipers
« Reply #37 on: June 09, 2015, 11:06:39 AM »
 do you mean the seal ? it is a square section rubber ring.they used to cost about £3,and fitting a new one
will improve piston retraction and seal ,well worth doing
regards
el__burro
Re: Brake calipers
« Reply #38 on: June 09, 2015, 10:22:39 PM »
I always use an old master cylinder and hose to pump them out, saves cleaning the grease out afterwards. Also its easy for a newb to damage the threads as they aren't really compatible and easy stripped.
Sent from my Nexus 7 using Tapatalk
Re: Brake calipers
« Reply #39 on: June 10, 2015, 06:23:49 AM »
If you mean the piston seal think of it this way---You only have one neck and if that fails you have no brake
