Author Topic: Curing simoniz engine enamel  (Read 7376 times)
Offline JustcallmeMrT
« on: February 08, 2015, 09:55:37 AM »
The can says to bake at 220 for 90 minutes to fully cure the paint.  As I don't have access to an old oven, I thought I'd spend some time with a heat gun and infrared thermometer....  anybody have any thoughts?
Re: Curing simoniz engine enamel
« Reply #1 on: February 08, 2015, 10:23:48 AM »
Don't think you will get the alloy up to temperature with a heat gun.
« Reply #2 on: February 08, 2015, 10:29:32 AM »
Nuts.
« Reply #3 on: February 08, 2015, 12:14:31 PM »
I guess just be careful till you can run it ,and let the motor heat cure it,
Online steff750
  • THE POWER OF DREAMS
« Reply #4 on: February 08, 2015, 12:18:21 PM »
Quote
you will cure it when you ride it  ;)
until i bought my brand new 1200 bandit 2000 i always wondered why i liked brand new bikes ,it was because they had a that lovely smell of the engine paint baking :P
« Reply #5 on: February 08, 2015, 02:34:06 PM »
Thanks for the help guys!
Offline tom400f
« Reply #6 on: February 08, 2015, 03:25:49 PM »
MrT is it the same stuff as here: http://www.sohc.co.uk/index.php/topic,4716.msg21542.html#msg21542
Didn't mention baking on the tin but as I was doing a brake caliper I put it in the oven at 100 deg for 30 minutes. But may be yours is different.
« Last Edit: February 08, 2015, 03:35:33 PM by tom400f »
1978 CB400F2 Yellow
1995 VFR750FS Red
1997 VFR750FV Lapis Blue
2013 Yamaha FZ8 Grey
Offline boilermaker1
« Reply #7 on: February 08, 2015, 06:28:50 PM »
I painted my engine a few months ago with Simonz engine enamel, I made up a big plywood box and lined it with tinfoil.
I got the idea from sohc USA forum.I purchased a cheap cooking thermometer on ebay, Used a heat gun to get it up to temp.
It took five hours. very happy with then end result. The directions on the can says that it must be cured within 10 hours of painting so running the engine to cure it may not be an option. I also read some where that curing paint by running the engine is not a great idea as the top of the gearbox may not get hot enough, and this is the place where petrol will land if the carbs leak
« Last Edit: February 08, 2015, 06:49:19 PM by boilermaker1 »
« Reply #8 on: February 08, 2015, 07:17:41 PM »
Sweet tip!  May well give that a try!
« Reply #9 on: February 08, 2015, 08:18:18 PM »
Mr T
Nuts is a famous quote from the 2nd ww.You related some where there? ;) ;)
Bitsa
« Reply #10 on: February 08, 2015, 09:40:17 PM »
Same stuff, at least the tin looks the same.  I had read the thread you linked so I figured it was worth asking to see what  others had experienced.
« Reply #11 on: February 08, 2015, 09:45:07 PM »
Mr T
Bitsa
You'll have to enlighten me Bitsa.  :)
Offline Norniron
« Reply #12 on: February 08, 2015, 09:50:17 PM »
Another tip,if you do this!
Do it as far from your house,garage or shed as possible and use a circuit breaker for the heatgun
1977 400 cafe
1972 500/4
2013 triumph STR675
Offline Norniron
« Reply #13 on: February 08, 2015, 10:05:47 PM »
If you want to make a safer oven use one of these lined with tinfoil.
Probably work out the same as a couple of sheets of ply
1977 400 cafe
1972 500/4
2013 triumph STR675
« Reply #14 on: February 12, 2015, 07:04:20 PM »
Job done.  Thanks folks!
