Author Topic: K8 rear brake wear indicator pointer  (Read 1190 times)
Offline martin_uk
« on: February 14, 2015, 05:28:38 PM »
Does anyone know what is correct part number.
CMSNL show item 8 as a brake rod, DSS have same problem.
http://www.cmsnl.com/honda-cb750k-750-four-k-1978-usa_model7244/partslist/F++10.html#results
CMSNL have same description on K7.
Original one seems to have run away to start a new life for itself ;)
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline martin_uk
Re: K8 rear brake wear indicator pointer
« Reply #1 on: February 14, 2015, 05:58:57 PM »
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline martin_uk
« Reply #2 on: February 17, 2015, 10:36:13 PM »
Just goes to show how useful it is to take lots of before images.
There I was thinking that the pointer had done a runner only to find it was not there when I got the bike :-[
2014_1206Kparts20062 by nitram2010, on Flickr
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
« Reply #3 on: February 18, 2015, 08:09:15 AM »
There Is a story about them mate.
When the shoes wear and there is no adjustment left you can't move the arm round a spline as there is a big plain bit----unless you file one spline out of the arm, but then of course the indicator points too close to the mark so it becomes what is known in the trade as a wheeee bit(place in palm of right hand and throw over shoulder whilst yelling wheeeee!) some times also know as bungmebits
Offline Erling
« Reply #4 on: February 18, 2015, 09:25:13 AM »
I bend a piece of metal 3mm thick round the brake shoe "foot" 40 years ago on my CB750.
Had to use them also when new shoes were fitted around millennium change!
There were about 0.5mm lining left on the most worn brake shoe!
    Erling.
