Author Topic: Wiring in headlamp 400/4  (Read 2342 times)
« on: March 08, 2015, 12:17:57 PM »
Hi Chaps.
I had a slight problem with the handlebar switches. Could not get horn to work all the time and no main beam up and no headlamp flasher / passing light either. Took left hand switch apart, cleaned, re sprung the springs a bit. Horn now working, now have main beam, a mystry to me as I thought that all happened on the right hand side!!. Also had spaghetti wiring out of headlamp bowl, to check connections etc. Anyways, the passing light is still not working, does it only work when engine running?.
Ta in advance
« Last Edit: March 08, 2015, 12:28:51 PM by Nurse Julie »
Offline mike the bike
Re: Wiring in headlamp 400/4
« Reply #1 on: March 08, 2015, 12:49:11 PM »
The Pa switch puts 12v on to the blue wire (which is main beam).   The engine don't need to be running, just the key turned to the on position.   It sounds like the switch isn't quite right after all that fettling
« Reply #2 on: March 08, 2015, 04:42:56 PM »
Hi Chaps.
Ta in advance
How do you know the head light flasher on the horn button worked before you started tinkering ?
« Reply #3 on: March 08, 2015, 08:52:35 PM »
Thanks Mike the Bike, will look at switch.......again!!!.
Trig, good point, I don't know if it was working or not, never use lights, I don't go out after dark  ;D ;D ;D
« Reply #4 on: March 08, 2015, 09:08:00 PM »
Take all the light off and have it on a day time only MOT  ;) ;)
« Reply #5 on: March 08, 2015, 09:10:12 PM »
I'd lest the continuity of the switch with a meter.  You can get a meter for a few quid and they're very handy for fault finding.
« Reply #6 on: March 08, 2015, 09:13:56 PM »
Yer, my local MOT centre does those sort of MOT's for us girlie bike riders. They know we don't like being out after dark, what with all these strange men around  ;D ;D ;D ;D ;D ;D
Offline tom400f
« Reply #7 on: March 08, 2015, 11:10:57 PM »
Questionable whether an original 400F headlight is good for anything else other than daytime in any case....  ::)
1978 CB400F2 Yellow
1995 VFR750FS Red
1997 VFR750FV Lapis Blue
2013 Yamaha FZ8 Grey
Offline DayvW
« Reply #8 on: March 09, 2015, 01:54:59 PM »
+1 :)
