Author Topic: Starter Motor Not Working  (Read 7031 times)
Offline Drew400
  • 400/4 I restored
« on: March 12, 2015, 07:20:57 PM »
Hello all,
As my previous thread (http://www.sohc.co.uk/index.php/topic,7852.0.html) was leading this way, I thought I'd start a new one to make future searching for anyone a bit easier.
It seems that my starter motor is dead.
Step 1 - My meter is showing 12v from the solenoid when I press the starter button so I have removed the starter and now require your expertise (having never before stripped a starter motor).
Step 2 - I put a car battery between the body of the starter (-ve) and the power lead only to see a flash and no movement from the cog end before I rapidly pulled it away again.
Next step, removed the bolts to reveal the innards, as per the pictures below. A couple of things struck me: 1) should there be sheathing on both of the wires leading to the brushes? 2) I picked up a loose piece of metal that you can see resting on top of the body near the unsheathed brush. Can't see where it might have come from.
Any advice (such as buy a replacement starter motor!) very much appreciated.
Cheers, D.
Previous bikes:Puch Maxi 50, CD175, Suzuki T500, CX500, Z200, GS850, XS1100, GT750 (kettle), RD400, GTR1000 (not too many boastables in there!), CB750F2 Phil Read Replica
Offline tom400f
Re: Starter Motor Not Working
« Reply #1 on: March 12, 2015, 10:48:36 PM »
I imagine the unsheathed brush is the -ve one and therefore that's OK.
You can check for continuity between the +ve terminal and the sheathed brush, or more importantly no continuity between the +ve terminal and the motor body.
Don't know what the mystery piece of metal is.
1978 CB400F2 Yellow
1995 VFR750FS Red
1997 VFR750FV Lapis Blue
2013 Yamaha FZ8 Grey
Offline mike the bike
« Reply #2 on: March 12, 2015, 10:55:19 PM »
It looks like a bent commutator segment bur I assume the segments are all OK otherwise you would have spotted it.  Brushes look ok though.  I'd give it all a good clean up and it might make sense
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #3 on: March 13, 2015, 04:31:45 AM »
Hi Drew,
Starter motors generally robust bits of kit that rarely give trouble.... bad luck!
That bit of 'swarf'... if its not obvious then perhaps a chip off one of the body magnets... they are brittle & can chip. Do have a good look around - there may be more awaiting their freedom.
Agree with Tom on the sheathing issue.
(1) Your meter showing 12v off the solenoid does not imply that the solenoid can supply the 80 or so Amps necessary to spin the stater. The weeny horn switch too will show 12v coming out of it ... but no way would it supply the starter. Point is... it may indeed be the solenoid is 'worn'. To check this I previously suggested you held a big screwdriver across the solenoid 'big' terminals ... (ie bypassing the solenoid workings)... if you did this, and no spinning, then indeed it points to a fault in the starter motor, its earthing (& battery too), or main +ve lead supply.
(Presumably you're 100% happy with all the wirings, crimped connections & ALL earthings.)
(2) Yup... always biggum sparks.... even with a healthy motor. I presume before you did this, that it turned freely?  Point I'm making is did you give it a 'manly' connection before bottling out due that big spark. (no offence Julie!)
As Mike the Bike suggests, I'd just clean it all up & put it back. Try putting the spindle in an electric drill, and on a lowish speed, and with some fine emery paper / 1200 grit whatever, gently polish up the commutator. Then with a soft pick (eg wooden toothpick) scratch out all the embedded (soft) carbon from all the 'slots'. Clean all aspects of the brushes / mounts, then grease all spinning bits  all up lightly & reassemble.
I've not checked (Honda) ... but recently bought 2 pattern starter motors for my Seadoo jet boat. Came in at $49 USD each.... wow, what a bloody bargain. (they were beyond repair due seawater)
« Last Edit: March 13, 2015, 04:36:52 AM by Lobo »
« Reply #4 on: March 13, 2015, 06:58:25 AM »
Not sure on extra metal but if it was inside it has to have broken off something which is worrying, Commutator (copper segmented bit that brushes run on) looks overheated to me and is one of the worst Ive seen also brushes seem worn odd.
Conclusion, good used part is probably cheapest and easiest fix
« Reply #5 on: March 13, 2015, 07:53:51 AM »
That com looks OK to me, just needs a clean up as Logo suggests.  When I worked for Hotpoint, there were brushes that looked a bid ragged and sparked a lot so..
Clean everything up
Clean in commutator
Fit new brushes
Offline Drew400
  • 400/4 I restored
« Reply #6 on: March 13, 2015, 08:15:00 AM »
Thank you all very much indeed!
I guess my manliness was inded tested to the limit with the car battery, but I got nothing when I shorted across the solenoid (using a spare earth lead rather than a screw driver). I am (was) indeed happy with the earthings, etc. because it was spinning on previous (post-rebuild occassions) and it was spinning at the moment it went wrong.
I will now do a damned good cleaning job on it and brush out (air compressor?) all the innards. I'll then reassemble it and report back. Job for Sunday.
Have a good weekend all, whatever you're doing.
Cheers, D.
« Reply #7 on: March 13, 2015, 11:37:15 AM »
Have to say Drew the bushes I replaced are in far better nick than yours.Probably the same you can have em if you want
Bitsa
Offline Frisky
« Reply #8 on: March 13, 2015, 12:43:25 PM »
Hey Drew,
If you need spares for your starter motor, give us a shout as I have a couple in various states of repair.
Frisky
Offline Drew400
  • 400/4 I restored
« Reply #9 on: March 13, 2015, 12:46:22 PM »
Thank you both. I'll pm you if I need anything.
Cheers,
D.
Offline ka-ja
  • ken
  • yoshi 460
« Reply #10 on: March 13, 2015, 03:52:24 PM »
Hi,
    Broken bit ressembles the captive end of one of the brush springs-previous repair left-over?----Ken
nice bike,nothing in the bank
« Reply #11 on: March 13, 2015, 09:55:41 PM »
Well spotted
Offline Drew400
  • 400/4 I restored
« Reply #12 on: March 13, 2015, 10:00:08 PM »
Thank you too, D.
Offline Drew400
  • 400/4 I restored
« Reply #13 on: March 15, 2015, 03:33:53 PM »
Hi all, fault found.
The inner wiring loom, at the point it is connected to the copper +ve terminal post that protrudes through the starter motor body, is completely shot. The odd piece of metal comes from that connection.
I've tried all sorts of ingenious ways to repair it with no success. Indeed, there is evidence of previous repair work in the same area.
Probably need a replacement motor unless the innards are available anywhere. Investigation under way.
Another piece of the colourful learning tapestry that is my 400/4!
Cheers,
D.
Offline ka-ja
  • ken
  • yoshi 460
« Reply #14 on: March 15, 2015, 04:54:04 PM »
Hi,
    At least you have a definative answer to your trouble-well done, maybe Steve at 400/4 bits can sort you something out---Ken
