Author Topic: Valve lapping  (Read 1817 times)
Offline andeks
Valve lapping
« on: May 07, 2015, 02:03:48 PM »
Hi all,
Have just registered but have been viewing the forum for a while and seen some great replies to calls for help and advice about restoration of  400/4's.
I am attempting a rebuild of an early model ( with rear footrests on the swinging arm)
I have taken head and barrels off and I am at the moment lapping the valves in.
Inlet valves are lapping in nicely but exhaust seats are pitted.
Does anyone know if there is a limit to lapping in, sure I read somewhere that the valves can only be taken back a certain amount.
Any advice would be gratefully received.
Dek
Offline martin_uk
Re: Valve lapping
« Reply #1 on: May 07, 2015, 02:29:59 PM »
Hi and welcome.
It is usual for exhaust valves/seats to deteriorate first as get much hotter.
General rule is that if you cant get rid of pits by lapping with coarse paste, will need to re cut seats.
You can try using an electric dril on stem to rotate, but keep lifting valve up and only do for very short period, say 10 secs.
Finish off with fine pasted by hand and make sure you remove all paste.
Wide seats will effect performance, but IMHO unlikely to notice on a 400
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Re: Valve lapping
« Reply #2 on: May 07, 2015, 08:36:34 PM »
Hi all,
Dek
Welcome, It depends how bad the pitting is on the seats ?  ( on close inspection on Mr T's head, he needed the seats cut ) Seats can be re-cut and valves dressed. These valves and seats can be cut due to they are on a adjustable tappet. You only have to be careful if the engine has shims, as the more you cut the more the valve sits higher.
Offline andeks
Re: Valve lapping
« Reply #3 on: May 08, 2015, 07:17:42 AM »
Thanks for great advice, just another question, where and how can I get the seats re-cut ?
Once again thanks for the replies.
Re: Valve lapping
« Reply #4 on: May 08, 2015, 07:27:38 AM »
An engine machinist who specialises in motorcycles is the best bet, car one tend not to understand the tolerances on bikes
Offline andeks
Re: Valve lapping
« Reply #5 on: May 08, 2015, 11:59:26 AM »
Thanks Bryan.
