Could do with some help / guidance / experience on carb rebuilding please !
Carbs are all stripped for cleaning and new gaskets & O rings, but it appears someone has already been playing as some of the parts were not in the same order in each carb !
From what I can see in the parts diagram, I should have the following order of parts on each of the throttle shafts that enter the to p of the carb bodies;
• Captive washer / Spring holder
• Spring
• Felt washer ?
• Stepped plastic bush that locates into the body housing
And then inside the carb body;
• Plain plastic bush ~ 4mm wide
• Throttle / slider arm with securing screw and lock tab
Does that sound right ?
Next question re’ needle valves – I’ve renewed the O ring, but the valve body now doesn’t sit very far into the casting and as a result the locating tab does not sit flat against the casting. So either I’ve used an O ring that’s too fat, or, it’s normal for a new O ring, and I should adjust the float height to compensate - any thoughts or experience please ?
Thanks in advance for any help !
