SOHC.co.uk Forums > CB350/400
CB350F a couple of easy questions
mike the bike:
Plastic doofer =17271611010 breather chamber. Its supposedly a device, not fitted to 350fours, to decrease harmful emissions. They obviously don't work otherwise VW would be using them.
Bullit:
That's it Roy. Could have sworn mine joined together at some point though.
Like the VW pun there Mike 👍
royhall:
Job done. Just fitted the new breather pipe on the bottom of the plenum chamber. Turns out it has a little air filter element fitted at the top so it doesn't matter if it sucks air in via the breather/drain. Clever stuff, that's another for the knackered old memory to retain.
Gixxer-18:
If it helps this is my breather tube, the outer sleeve is hard and brittle but this was how it was fitted to my bike, I haven't removed it yet as it will be destroyed when I split the crankcases tomorrow.
HTH
NIGEL.
royhall:
Cheers for that and welcome to the forum. I assume from the name you also have a Suzuki. That's exactly how mine has gone back.
Navigation
[0] Message Index
[*] Previous page
Go to full version
