Other Stuff => Tricks & Tips => Topic started by: martin_uk on November 22, 2014, 01:10:33 PM
I dont have a lathe and needed to turn down an M6 bolt to replace a broken seat stud.
It is not visible once cover fitted, but I like to play ;D
I am sure many of you will have used a drill mounted in vice with a file to shape, but it works even better if you have a grinding wheel.
Mount the bolt in drill and whilst operating drill and grinding wheel, shape the bolt against the wheel.
This gives a much more even finish.
Drilled out the stud and counter sunk.
(https://farm9.staticflickr.com/8653/15663278300_dea9f6b479_c.jpg) (https://flic.kr/p/pS7oWq)2014_1122kparts0052 (https://flic.kr/p/pS7oWq) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
(https://farm8.staticflickr.com/7501/15664677039_a36050c17a_c.jpg) (https://flic.kr/p/pSeyJB)2014_1122kparts0054 (https://flic.kr/p/pSeyJB) by nitram2010 (https://www.flickr.com/people/46578358@N07/), on Flickr
I later added a bevel to allow bolt to fit counter sunk.
Will need welding to finish
