SOHC.co.uk Forums => CB500/550 => Topic started by: deltarider on February 20, 2020, 11:07:35 AM
What gloves do you guys use to protect your hands when doing maintenance? Vinyl, latex, nitril?
Marigolds, from the supermarket for dirty work 😊😊😊😊 Or, Triggers Black Nitrile medical examination gloves.
[attachimg=1]
Dissposable Marigold Industrial vinyl. They have a light dusting of talc on the inside and this makes them easy to get on and off. I can get two 'wears' from a pair before they split.
I put a pair of household marigolds over the top if I am using the parts washer though to stop them swelling up.
If I'm using the parts washes, I use a pair of industrial grade, chemical resistant gauntlets that go right up to my shoulders. If I want to remove my nail varnish, I go gloves free, especially in the cellulose thinners tank 😂😂😂
Black Nitril gloves. Box of 100 from Amazon about £8.00.
Gloves? What are yer a man or a mouse 😂😂
If doing a mucky job I use pair of rubber gloves with pair of lightweight industrial nitrile over top.I once superglued my fingers and thumb to a car roof rack🤭 and always wear rubber gloves since 😂😂
For my level of garage skills I use a pair of these.....
These are the best i have ever found can use them over and over as they don't rip like a durex ;D
(https://i.imgur.com/4KcHj5c.jpg)
Same as ours Paul but Graham looks stooopid in orange
And Pink and blue come to think of it he ;) ;)
That's true Paul (https://uploads.tapatalk-cdn.com/20200220/46a49ba9272abef50e44e92c3a570b11.jpg)
Sent from my I3312 using Tapatalk
I'm using these, nitrile. They are strong enough to sustain most of mechanical "load" and resistant against fuel, brake cleaner etc.
Sometimes I can use them more than once, depending how long and what I'm doing. Using them practically always when doing something in garage..
100pcs pack is around 8eur(https://uploads.tapatalk-cdn.com/20200220/f2cfec56f9cfa83f0663f3d89e3b42de.jpg)
... as they don't rip like a durex
But... you are not supposed to force a hand, let alone a fist in a durex, Paul. ;D
Thank you all! Great info!
But... you are not supposed to force even one hand in a durex, Paul. ;D
Depends what you are up too ;) ;) :o
Is that why Andrew-S uses boxing gloves. ;D
OUCH :-[ :-[
