SOHC.co.uk Forums => CB350/400 => Topic started by: davecara on February 02, 2016, 05:16:41 PM
I'm about to start my resto proper on the 400/4 I'm doing with my Dad.
Can anyone advise what the oe finish was on the frame? Ie paint/powder coat/stove enamel?
And, what would be best to replicate it? It's a budget but and bolt resto (if there is such a thing!) but I don't mind paying out for a great finish.
Any help or advice appreciated!
This is a great debate, I always powder my frames as they are used in all weathers. If going for a black frame, go for satin black as gloss looks too tarty and the satin is a good match.
I recently had mine powder coated black with a zinc chromate undercoat. It looks good and seems to be well attached.
£97 for frame and rear forks including sand blasting, which I thought was reasonable.
£97 seems bloody brilliant seeing as Ive just had one quote back for frame and swingarm in satin for £175!
Not sure where you are mate but the company is Rugby Powdercoating, 19 Paynes La, Rugby CV21 2UH. I found them really helpful and they're fairly close to me.
www.rugbypowdercoating.co.uk/
You will need all black metal parts done, frame, swing arm, centre stand, side stand, bottom & top yoke, battery box, foot pegs, clock bracket ect,ect. This will save you a ton of hassle later & all will match.
I wasnt going to get the Yokes done as in my experience it doesnt look right, powder seems a bit too thick if that makes sense? I was just going to get the frame, centre and side stands, peg mounts and the headlight and clock brackets. The rest will get painted
Looks fine to me on the yokes. I am getting on a bit and my eyes are not what they used to be ;) >>
had all my yokes done and they look great. 8)
We don't really want to know what you do with your yokes Paul ;D ;D ;D
Hard or runny they are fine Trigger, but never snotty :-[
I painted mine, easier to touch up if you get a chip.
I would not powder coat it simply because they were never powder coated.
I think RAL 9005 satinblack paint comes very close.
I kinda agree... zinc, primer, coro-protect undercoat, 2 thin layers satin black...
I'd also fear unseen corrosion pockets building underneath...
I know some Z1 Kawa and some CB750 KO guys that deeply regret to have powder coated their bikes.
Hard to get rid of that stuff once its there.
I just did my frame, Stands and yokes using Hammerite Smooth rattle can and 2 coats and it's gone on really well with a good finish.
Having said that the frame and swing arm especially were in great condition already with only a couple of minor marks and small surface rust.
We'll see how it hold up but I will never use this baby in the wet anyway ;) ;) ;)
That's the comment I was waiting for! I'm going to get they frame and swinger media blasted and then I'll zinc prime and paint them :)
Personally, I cannot understand why your going that route. Every black metal part on my CB400/4 is powder coated. It is so practical, fuel and brake fluid resistant and after doing 3.500 miles on her last summer, a quick wipe down with the baby wipes and she was as good as new again. Well, better actually as powder coat was not around in the early/mid seventies so I feel this finish is a vast improvement on the original finish. I have another bike that will have exactly the same treatment to ALL black parts as part of the restoration as I know it will last a very long time. The Hammerite will peel like a bad suntan, as I have unfortunately found to my cost in the past, if you get any brake fluid on it and any petrol will make the finish go like a sticky mess. each to their own though.
I must agree with you Paul and going the paint route , at least you can touch in or spray in anytime as with powdercoat not , two pack is very durable to oils etc. And more like stove enamel as they call it , I know people have two packed over powdercoat ..
I have found that when I have picked up a chip in the powder coat, a quick blow over with the hairdryer 'melts' the coat and the hole fills itself in.
Hey better not take the bike touring a hot country Julie otherwise there maybe a big pool of powdercoating on the floor when you've parked
;D ;D ;D ;D ;D Oh for some sunshine and heat to try the theory out Phil
