SOHC.co.uk Forums => Other Bikes => Topic started by: Moorey on October 07, 2019, 04:47:13 PM
Just before we came away to rainy N Wales I took the 400 super four for test and as I wheeled it in one of the rear Showa shocks decided to drop all its oil on the floor. Now these don’t crop up second hand very often, new ones are about £600 each so that left having a rebuild or buying something different. Time seen a factor I plumped for buying others, and took a risk on a pair of cheap Chinese shock off EBay . I have now done about 200mls on them around wet Wales and both of us think they ride nicer than the original Showas with these been a bit stiffer which is what we wanted. If they were to only last 12 months I would be quite happy with them. Cost a ridiculous £55 a pair. Hopefully the weather will be better over the next few days .
[attachimg=1]
TEC do an acceptable set of rear shocks for the sohc 4's
https://www.ebay.co.uk/itm/340mm-13-Motorcycle-Shock-Absorber-Rear-Spring-Damper-For-Yamaha-XJR1200-Honda/383177623912?fits=UKM_Make%3AHonda&hash=item59372a8968:g:CH8AAOSwRdFdjcqu
If you use his compatibility checker, it will actually tell you it will NOT fit your machine
I've just bought these for the k6 Cafe Racer project - https://www.ebay.co.uk/itm/TEC-All-Alloy-Gas-Shocks-Shock-Absorbers-Honda-CB750-K0-7-SOHC-Models-21fxm4/272336717682?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
The bottom 'eye' fitting screws off and the 'u' fitting (provided with the shock) that fits the swing arm screws into the shock.
Haven't used them yet but visual quality looks good
That's right because they are 10mm longer than standard but I was ok with that. The main purpose of the post is to show that even though they are very cheap they seem at this time to be of a decent standard. Anyone wanting new shocks should look through the specs of different ads and they will more than likely find some that has suitable specs to their requirements at what I consider to be a very low cost for a pair of brand new shocks. I wouldn't be surprised if the TEC ones were made in the same factory.
All you need is a pair of Ohlins stickers and jobs a good un!
They will nearly cost as much as the shocks . ;D
I have it on good authority RFY shocks are the way to go. Apparently Ohlins are so yesterday. I read it on internet so it must be true. ;D
