SOHC.co.uk Forums => CB750 => Topic started by: Andrew-S on August 27, 2019, 03:28:37 PM
Looking to replace the side panel grommets on the K1 ......the Parts book lists two part numbers for the left side panel top grommets, item No1 on the diagram below: 17247-240-000 and 17247-303-000
DS supply both part numbers which appear to look the same, so grateful if someone can please advise which is the correct one?
17247-240-000 - https://www.davidsilverspares.co.uk/parts/by-part-number/partnumber_17247240000/ (https://www.davidsilverspares.co.uk/parts/by-part-number/partnumber_17247240000/)
17247-303-000 - https://www.davidsilverspares.co.uk/parts/by-part-number/partnumber_17247303000/ (https://www.davidsilverspares.co.uk/parts/by-part-number/partnumber_17247303000/)
Andrew
According to that page it's the 303 type as the 240 type was only used on the K0 not the K1.
Check your frame number is above the cutoff number shown to the right.
Many thanks - frame is well above the cut-off.
