SOHC.co.uk Forums => CB750 => Topic started by: mortyboy on April 17, 2022, 05:16:07 PM
I'm making my way through my rebuild and notice I'm missing a part for the starter gear:
https://www.cmsnl.com/honda-cb750f1-super-sport-1976-england_model14680/pl-gear-set_28109300000/
It doesn't seem to be available but looks very simple. Does anyone know of a work-around, ie using/adapting a standard washer?
Cheers :)
Its an odd size and hardened from memory
I was short of this washer but a member had a spare one but spotted this on ebay that includes the washer - expensive for a washer but better than none! The 'shim' is hardened - I can provide sizes if you want but before I got one, I struggled to find anything generically that was similar
https://www.ebay.co.uk/itm/353855811825
List sizes please Phil as the cb1300 uses a gear exactly like that one and it could be near identical and thus usable
Here you go - OD 39.88mm - ID 12.25mm - 1mm thick
[/thankyou Bryan
Brilliant, thankyou!
That's great and really helpful. Thankyou very much. I have a new lathe & mill arriving soon so will try to run one up - along with a few other parts!
Problem is it's more of a hardened shim than a washer ... there are loads of places who do custom hardened washer/ shims in the UK. I had some made for my CB500/4 valves.
If it's the same as the K1 i have one somewhere.
I could not find mine in the pile of bits that came with the bike, but you guessed it I managed to get hold of one and then found it.
I will have a look tonight.
Same for all years Paul
Just got to find it now then ::)
Found it ;D
