SOHC.co.uk Forums => CB350/400 => Topic started by: billdn on August 26, 2018, 11:17:39 AM
I need the grommet for the top of the left hand crankcase cover,I can't find a part number- is it easy to make one or does anyone know who makes them or how. Ideally also need the one that goes around feeds from stator and field coil also.
No separate part number, its all part of the loom. You could cut one out of a block of rubber, if you have the patience.
[attachimg=1]
Same as....no separate part number
[attachimg=2]
You could try Steve at 400fourbits.co.uk
He may have a useable one.
Peter
I bought the leads from Steve 400/4 bits at a reasonable cost
The grommet is part of the sub-loom item No. 31110-333-000
I made a batch recently (as image) PM me if you are still looking for one.
