SOHC.co.uk Forums => CB350/400 => Topic started by: THUNDERDOWNUNDER on June 22, 2019, 06:14:39 AM
Just put a set of clocks from a CB 350 on my bike as the original speedo gave up the ghost .Does anyone know if they are compatible ? Thanks !
Same sized wheels on both, speedo drive same so that should be ok. Rev counter drive mech the same on both. You already know they fit so there should be no problem other than different colour faces and top speed marking. I had 400 clocks on my 350 for a while because I had a decent spare set.
Ian
Thanks Ian , I was told they redline differently but butthe speedo looks the same .Rob
