General => Announcements => Topic started by: sand5858 on May 25, 2015, 02:11:08 PM
CB 750 sandcast can not idle at low rpm.
I have tried to adjust the throttle cable up through the throttle but it seems to adjust well beyond. I have adjusted the air screws around one turn out. Is there anyone who can come up with good advice to my carb problem.
Tony
Denmark
Have you checked the idle jets/emulsion tubes are not clogged up?
