SOHC.co.uk Forums => CB350/400 => Topic started by: Pops400 on November 06, 2016, 08:18:17 AM
This bike hates me....
Is someone playing a joke on me? Drain plug appears to be 9mm hex. 9mm!!! Every set I have has 8 & 10mm, can't find a 9mm anywhere... Not even in a drain plug kit...
Is this right, or am I right in saying it's wrong and it wouldn't have been a hex way back then?! >:(
Can't even find a local shop to buy a 9mm from on a Sunday...
From memory so probably wrong, should be a 14mm head hex bolt.
Have you got a Halfords near you, I think they do a brake caliper tool that's a 9mm Allen. If that's what you're referring to.
Image of the part from CMSNL.
3/8" is 9.5mm so probably too big. I'd be tempted to go with the mole wrench if you can get it on, hopefully the thread in the sump is OK.
[attachimg=1]
Thanks Peter / Chris
Sat outside Machine Mart waiting for them to open... That engine is coming out today. >:(
