SOHC.co.uk Forums => CB350/400 => Topic started by: Matt_Harrington on September 05, 2022, 06:19:30 PM
There is a shaft on the plate that holds the carb bodies together. This shaft has the throttle quadrants on it.
I would like to remove this shaft from the plate to re-plate the quadrants. Is it held in place with a brass pin? - ie does this require drilling out?
Yes it needs drilling out Matt.
Once I drilled mine out I replaced it with a roll pin, worked a treat.
Thanks guys. Answers my question - and in a thrice!
