SOHC.co.uk Forums => CB350/400 => Topic started by: Mikep328 on July 21, 2023, 06:46:08 AM
Hi all! A few days ago I acquired a '76 CB400 four, took it out for my first ride. Fun little bike...except for the front brake which I found totally inadequate.
Subsequently I found this site and read all the posts I could find, seeing much re the "wooden" feel and generally mediocre stopping power. On my bike the lever is firm, no sponginess. It just doesn't apply any real stopping power, regardless of how much pressure I apply on the lever. The bike has 13,276 miles and is in excellent, well serviced condition with a lot of receipts for work done, to include replacing the cam chain tensioner as well as other engine "freshening." The only modification to the bike from stock is an electronic ignition.
I contacted a well-known vintage Honda spares supplier, asking them for recommendations to improve the brake. I was surprised that rather than trying to sell me a new rotor, new lines, new master cylinder, etc), the response was, "New pads may help but the brakes on a CB400F were never great." :(
The front brake feels pretty much the same as the stock front brake did on my '73 Norton Commando - maybe even a bit worse - before I replaced the OEM master cylinder with a Brembo from Colorado Norton Works. That, a set of braided SS lines, and some more aggressive pads in the OEM caliper transformed that brake. It is now acts and feels like modern brakes. Of course the down side is that the master cylinder does not look anything like the OEM version.
My general thought is to go down a similar path though from searching and the suppliers response, it doesn't sound like anything is going to make the sort of transformation I am looking for.
So...I'm wondering if anyone has done something similar (different master cylinder) or found some tricks/tweaks/mods to the OEM front brake that I have not managed to find via the search function. Also, what are the most aggressive brake pads for street riding, including aggressive riding on narrow, twisty roads? I don't care about rotor wear. If I had to replace a rotor every 10,000 miles to get good brakes, that's fine.
Thanks!
Welcome to the mad world of the SOHC ;)
It is a 70's bike and they don't have modern braking grip or stopping power. They were just a simple upgrade from a drum brake.
Welcome Mike- great forum this.
I have exactly the same diagnosis about my 550k front brake which has a new master cylinder and caliper piston and pads. Pull as hard as I think reasonable with full hand not two fingers and retardation is pathetic- need to use rear brake all the time. Pads did not look especially glazed. My plan is to rebuild with braided lines and to clean the disc very thoroughly.
Also need to check the master cylinder piston diameter which should be 14 mm. Some aftermarket units are 5/8 th inch which is 15.9 mm and that would increase the wooden feel. Also I have read that as a first disc brake effort Honda were worried about lock ups so made it intentionally weak.
A double disc conversion seems quite common on the 500/550 but I do wonder if a smaller diameter mc piston would help. The lever movement is very small so I could cope with more travel. Not seen any recommendations for smaller diameter master cylinders. Agree that safety is a much more important priority than originality.
Hi Mike, welcome to the forum, great place to be with very helpful people. I too have the pathetic front brake on my 550. But as advised going to give it a good toasting to bed it in properly. Nothing to lose.
Its easy to say you dont mind changing rotors but finding one isnt, no aftermarket to my knowledge.
Pads will make difference, as will making sure the pivot is free and caliper adjusted, lines might make a small diffeence if yours are original.
Apart from that its just brake earlier!
Aftermarket are available but, don't know if you can believe Slivers sales pitch >> https://www.davidsilverspares.co.uk/CB400F-SUPER-SPORT-FOUR/part_257875/
Thanks Graham, been a long time since i looked on his site, only when desperate now, sooner go to a mate in nashville!
i had a new repro caliper from silvers and the pads were terrible, dangerous in fact. Put some EBC ones on and much better but still not like modern stuff.
Interesting info guys, thanks. I had ASSUMED (you know what they say about assumptions) that David Silver was THE place to go for CB400 replacement parts.
I've now fitted Brembo in mine - very pleased with them.
Good point Bryan, I have been almost caught out riding along or behind others on modern machines.🥵🥵
Silver did have a lot of replica parts made when he "restored" a whole batch of 400's but some are, shall we say, not as good as others
agree with your assessment here. Its primarily the hydraulic leverage ratio that makes them feel so wooden and inert.
Of their contemporary bikes the Yamaha RD400 had much more potent front brake with significant difference in hydraulic ratio in comparison to Honda's very conservstive approach
The Yamaha used a fixed and twin opposed piston caliper (making similar ratio to two Honda type in double arrangements) that would feel good even now.
Later they went to sliding caliper and single piston but with different master, still potent but lost that absolute rigid bite the old twin pot had.
Changing mastercylinder ratio of the 400 4 should yeald good results, but as pointed out, unlikely to be accomplished with std looking components.
Thanks!
. Greetings, and welcome to the forum. People that are brought up with these vehicles were used to the braking standards of the time. The braking power available was quite sufficient for the tyres and other ingredients that were the standard in the 70's, and this included many of the four wheeled vehicles as well. As time passed, engineering and tyre quality improved beyond belief, you had to be bloody brave to try and make rapid progress on a wet road whilst your bike was still wearing its factory fitted Sensitol lubricated tyres!! Moving on to today, you are still riding a historic vehicle, if you want to ride with your knees and arse scraping the floor, then use a modern vehicle. In fact if you want aggressive street riding, along with aggressive riding along narrow country roads, I hope we never meet.
Some parts yes, but other a no.
Were are in the UK ? Maybe another member is close to you to compare, as i can get the lever sharp. Also look if it has a new aftermarket brake switch fitted, i have had problems with those recently ;)
Welcome Mike. I don't have any real complaints about my front brake. I'm not sure of the pads as they were fitted when I got here and I have a drilled/vented front disc....
I also ended up fitting the DS master cylinder as the original was beyond saving - much less lever free play.
Just got back from checking things out and then going for a quick ride. Brake caliper works properly - piston moves in/out smoothly, fixed-pad swingarm was correctly adjusted, I hadn't looked but turns out the brake lines are new and the pads appear to be as well. Don't know what brand they are.
Interestingly, the brakes seemed to improve a bit after some repeated heavy braking from around 85 MPH (indicated). After doing that, they seemed to react a LITTLE bit better. Or maybe I'm already getting used to them. ;) Definitely a fun bike to ride and I was pleasantly surprised with the engine response as the tach passes 6k RPM, heading for red line! :)
Sorted mine with a 93-95 cbr600 master cylinder and different levers to match, braided lines and new pads. Stops on it nose now and plenty of feel(https://uploads.tapatalk-cdn.com/20230721/6f389c670a8275a1702dd5fe6e33b9c5.jpg)
Over 6k is where the 400 four is most happy. Anything much less than that is more of a crusing speed and they were not built as cruisers. They just love being thrashed, using high revs in all gears, that is where they perform at their best. Up to the red line is it's happy place 😁😁😁😁
Yes, I know I blew the engine up on Hettie but it really wasn't my fault 😂😂😂😂😂
Don’t settle for the argument that you’re too used to modern brakes and this is just how they were in the 1970s. I rode a 500/4 in the 70 ‘s , a 750 in 2013 and had no issues with the front brake whilst accepting that it required more lever pressure than more modern bikes. My 550k sounds like your 400 Mike and while the lever is firm it’s like the lads are barely gripping. Could well be pad related. Don’t settle for lousy front brakes - if all the front brakes were as bad as mine there wouldn’t be many 550s around by now !
"In fact if you want aggressive street riding, along with aggressive riding along narrow country roads, I hope we never meet."
Sorry to hear that. I'll have my people talk to your people and cancel any plans for a get-together.
I'm definitely going to look into improving the brakes and, as I said, it wouldn't bother me to install a different master cylinder but going along with what David said, I owned other Honda 4s of that era and don't recall their brakes ever causing me concern. I'm NOT saying they were up to modern standards but they never scared me. Yesterday this front brake did! Admittedly, today, a bit less so. ;)
I'm planning on using SBS ceramic pads on my twin disced 500 after trying them on my 1300 and finding them excellent. I've got to say I replaced my MC with a Yamaha one back in the late 70/80s and I had no trouble locking the front wheel if I was a bit heavy handed, never got the bike to do a stoppie though, shame about that. I'm going the way of Roo and using a CB1300 MC which is the same as his CBR600 one, no good looking original when the bikes stuck in the side of a car, I'll take stopping every day.
;D
I've just been through this as I too found the front brake on my 400/4 pretty crap.
Master cylinder kit DSS
Made a new brake lever bush as the original had completely reverted to rust.
Braided brake lines. Wezmoto
Slave cylinder new gasket etc DSS
Pivot was seized so freed up
EBC pads Wemoto
Its much better but still not up to modern standards
Personaly stainless piston kit from Honda Classics along with scrupulous cleaning of eal groove.
Braided lines you can buy hose and fittings and make yourself or i can to your measurements at cost.
Master kit only needed if not pumping or releasing
"Sorted mine with a 93-95 cbr600 master cylinder and different levers to match, braided lines and new pads. Stops on it nose now and plenty of feel"
Interesting! Will the CBR master fit without any mods to the OEM CB400 switchgear or does different switchgear have to be used?
A CBR 600 master cylinder will be for a double disc and not for a 400/4 single disc. ;)
Ah! OK... I'm working/hoping to get adequate performance from the OEM but am wanting alternatives in case I can't get sufficient performance.
FWIW, my CB400 is going to be my normal rider, not a weekend or "special event" bike. Therefore, as much as I would like to retain the OEM gear/appearance, It's less important than being able to STOP.
I'm going with the CB1300 MC Mike, it has a mirror mount and a front brake light switch if you ever need to remove the one on the bottom yoke. Look identical to the CBR600 one although I can't see any mirror mount on Roos pic.
It all depends on what brake parts are old and worn out. Easy to do a full overhaul with, Stainless steel brake piston, new OEM piston seal, new brake lines and used a DSS aftermarket master cylinder or refurbish your original with a new service kit. You can always have the disc drilled for extra grip ;)
Or if you want a very good braking system, be prepared to spend £££
Yup, fits straight on and works fine with no immediate on/off application. No faults found and works perfectly. Really happy with the install and did so after much research from other sites and expertise elseware. Cheap option, dead easy to fit, the lot.
Recommended
As a new member you will soon find over members commenting on your post telling you that their bike has the best braking system but, they may or maybe not taking about a CB400/4 ;)
The Long Haired General wanted bar end mirrors which aren’t in at the min as it’s being fiddled with and sick of catching my pockets on it walking around the shop.
Yup, as it’s on a 409/4 thread, I was referring to our 400/4
OK! So if I understand correctly, the mid '90s CBR 600 MC will work with the OEM caliper/rotor on a 1976 CB400 four. Right?
There is no quick fix on a braking system .
Roo has forgot to mention that he doesn't have standard handle bar switches and his bike is £££ modified ;)
The CBR600 master is most likely a half inch or 12,7 mm, which is fine for a single 38mm piston caliper.
On all Honda masters the piston diameter is cast on the outside, most often facing the handlebars.
My up to date tech data Honda book only shows the spec for a CBR600 from 1999 and the size is 13.958 to 14.000 mm ;)
I've put a 12,7mm 1994 CBR600 master on my CBR1000F.....was 5/8 inch.
The photo I put up shows how modified it is. You can only fit corresponding levers with the master cylinder and it cost less than £80 for the cylinder, repair kit, paint AND levers. A good mod, cheap & works.
They fit the STANDARD bars that I have on the 400 so a quick fit also. Not the first to do this swap, loads have done it to sort the issue of crap anchors.
The master cylinder is a 93-98 CBR600, if you want the link to the levers let me know.
Happy to help
Had a revelation in the middle of the night re the brakes...(note that a "revelation" for me might be common knowledge to everyone else...)
It seem to me that by design the front brake is only half of a brake. The fixed pad cannot move and it does not touch the brake rotor if properly adjusted. SO...when the front brake is actuated, the piston moves ONE brake pad against one side of the rotor. It is the ONLY brake pad applying pressure to the rotor until your hand applies enough pressure for that pad to warp/bend the rotor far enough to engage the fixed pad. Frankly, this makes no sense to me, the rotor has to literally be bent into contact with the opposing pad before pressure is applied to both sides of the rotor.
Without a floating rotor, I don't see how such a brake can work effectively under any conditions. It seems to me that the only way to get a GOOD front brake is to either have a floating rotor with the current caliper or a replacement dual piston caliper.
Or am I missing something obvious here about the brake construction/operation?
You are missing a lot!
The "fixed" pad is mounted to the alloy bracket that pivots, or at least it should do, on the steel pin held by 2 small and one big bolt. The 2 small bolts hold an alloy bracket that SHOULD slide off the pin.
So when you aply the brake the piston moves out till pad touches rotor, then further movement brings the other pad to touch as the arm pivots.
If the clearance on "fixed" pad is too much the lever moves a long way, if too little the pad rubs.
The only thing that retracts the piston is the twist in the rubber seal which is why, unless the seal groove is super clean, the brake can drag and a dremel brush WILL NOT clean the groove, it just polishes the crud. You need a dental type pick and patiencs
Adding to Bryan's information, all single piston caliper have method to move the caliper assembly during brake pressure to pinch the static disc and make effective braking.
There's less swing calipers around nowadays, but many bike and car use sliding pins to move with pistons on one side only..
Floating disc, these are almost entirely to deal with control of disc expansion through heat range where used to avoid the disc going wavy and not to accommodate caliper geometry.
Ah, OK! Thanks!!! Makes perfect and obvious sense and I clearly misunderstood how it works. In my (rather thin) defense, we are in Italy on holiday at the moment and I was picturing the brake in my mind as opposed to looking at/examining its function it on the bike! Also, this is the first such brake (without opposing pistons) I have ever worked on though I apparently had them on several bikes years ago - Honda CB550, CB750. But I never worked on those brakes or felt that they were inadequate.
There is also a strong spring on the adjusting bolt to make sure the fixed pad moves away from the disc when the pressure is released.
I am however in disagreement with Bryan regarding cleaning the slot for the seal, a Dremel is ideal for this job, it's what you put on the end of it that matters. The abrasive discs I use will remove alloy, the crud that collects in the slot is hard but it's no match for the discs, I wouldn't use the most abrasive ones though, a 220 one should work to do the heavy work and then go up to 400 and 800 to finish off the slot.
I'm currently restoring a CB550 rotor cover that's been down the road and has some bad gravel rash on it, it's about 80% done and was restored using those discs, I'll post pics of it when finished and I'm sure you'll be surprised just how good these discs are for cleaning alloy, the inside of a caliper body for instance will look new after some light brushing with these discs and they are cheap, you can get around 27 pieces for £8.
https://www.ebay.co.uk/itm/314692515911?hash=item494522b847:g:oUQAAOSwoBRkpjs3&amdata=enc%3AAQAIAAAAwLV96za6Q43eRYqm8FJ6aiJrsd%2BoMDHOxQUCd77uPlqr9YduV6EDM17ZrfMDX6jnnJhylJvKR90AJgHLjPHwrkhs2j%2BKIIjLCKrpYplPDH1a7R5jztAskFfgw%2FTCRL78iyBS2Er3JP7H2oBUbNa90OZ4E8Isk1%2FmIYGOC98SI%2Fp8oUD2u%2BagCp5sDrIYTLYJgPTSNje1fip332tY7CmXh59xmm7dt8l87qnj66y1tpnqAIHIDjOhz2OBK6zbii3Dzg%3D%3D%7Ctkp%3ABk9SR6DyiM2zYg
I am with Bryan on this, any brush you use only polishes the crud, and as those discs, as you say, will remove alloy, the risk to remove more than just the filth is always there.
It is only one groove per caliper so how much time can you save by doing it mechanically in stead of by hand?
They aren't particularly aggressive Rob, sure they'll take alloy away if left there too long but they really only remove a few microns. Hence why I said not the most aggressive type which is 80 grit, that would remove any crud in there no problem at all, it wouldn't TBH do any particular damage if used lightly either. I've been using these for a long time now and know exactly what they are capable of and how to use them, I'd say anything pointed like a dental pick for instance stands a far higher change of damaging the alloy than these discs, as you can't really see inside the slot your sort of guessing how much is still left in the corners and how hard to use the pick. I've used these discs on my calipers and the result was really good, super clean and no damage visible.
Bryan is correct, no brush will get in the corners, so a nice angled pick cleans them in good order for a replacement seal ;)
I've been using the same tool for the last 40+ years, an adapted wheel spoke with two almost 90° bends and a flattened end, doesn't damage anything but scrapes dirt out of any corner without getting my hands in a knot ;)
Abrasive discs every time for me. There might only be one but the crap in that groove can be atomically welded in there that a pick simply won’t shift.
In doing further research, I found an instance where an owner of a couple of 400s noted that one had poor brakes while the other is OK. Both were OEM but there was no info re if they had different type of pads, etc. So maybe one was adjusted better/had more aggressive pads.
I have ordered two sets of pads - a sintered set and an organic set. I don't know what type/brand is in the bike at the moment but they have a different color backing plate to either of the two I have ordered so it's probably different than either of the pads I purchased. I am thinking that if different pads don't improve performance, I am going to purchase a Brembo MC with a 12mm piston and, assuming it makes the huge difference I expect, regretfully adopt the non-OEM look.
The 500 has the same front brake I believe - fitting Brembo Pads worked fine for me on my 500.
I guess it all depends on expectations - if you ride a modern twin front disc bike you will never be happy with the standard 400 set up.
Yeah, might be chasing windmills here...but my 400's brakes have to be noticeably better than they are right now to ride routinely and safely on normal roads with typical traffic/situations.
I'll advise if I find any improvement with either of the different pads.
My base for motor cycle brakes were the old drum brakes on British bikes. When I had my XJ900 the brakes were just fantastic but so was the performance. With my 400 the brakes were so much better than my Aerial Leader with similar performance.
Question...re the fixed pad/swingarm...
When the fixed pad is adjusted to have the minimum clearance is that spring on the adjusting bolt supposed to push the fixed pad/swingarm back to the established clearance?
This morning I found that even if I adjusted the bolt to provide far too much clearance, so I could move the caliper back/forth maybe 8-9mm by hand, once I applied the brakes and then released the lever, the swingarm/pad did not move back to the 8-9mm clearance. I had to push the caliper inward to re-establish the clearance. Is the spring supposed to be strong enough to do that? It doesn't seem to be very strong - easy to compress with my fingers.
Further... I pulled the caliper bolts to determine the type of pads. They appear to be sintered pads. No idea of the brand but "JB CR FF" is stamped on the backing plate. Don't know what that means. The pads are quite thick so appear to have very little mileage/use but there are grooves worn into the pads though the rotor is perfectly smooth.
Sounds like that pivot pin is starting to sieze up, the bracket needs to be super free
Bryan is correct about the pivot. plus the pads will be pushed away from the disc by a high spot to provide clearance.
Thanks guys...
I checked and the pivot pin/swing arm is very free/moves with no effort at all if the adjusting bolt is loosened to provide some clearance and I physically push the caliper in which forces the active pad back into the caliper and creates the clearance. But it won't return to that clearance on its own once the brakes are applied/released. The spring cannot force the active pad back into the caliper to "open up" the clearance. I suppose it doesn't really matter - it's common for disc brake pads to JUST touch the rotor even when the brakes are not applied but if the 400's pads are supposed to stay in light contact with the rotor, what's the point of the spring?
The spring is not there to force the active pad back into the caliper Mike, it's there to push the arm backwards so that when the active pad retracts the arm moves away from the disc allowing the clearance needed to stop the brake dragging. It's the piston seal that pulls the piston back into the caliper, as the piston moves out the seal distorts, it's this distortion that applies pressure to the piston and the seal trying to retain it's shape that pulls the piston back. It could be that the piston is pulling back but the pad is not, the pad should be just ever so slightly loose in order for the arm when it's being pushed back by the spring pushes the pad back into place.
If you remove the caliper and test the arm you'll find the spring is plenty strong enough to push any movement to the left back again, maybe test that and see if the spring has lost it's tension or maybe it's the wrong spring.
Thank You! With the caliper removed (or just loosened), the spring easily moves the arm/pad back on its own. The piston/pad is not noticeably retracting back into the caliper when brake pressure is released. I'm now wondering if a new seal is needed. Sounds like caliper disassembly/inspection would be a good thing...
The groove the seal is fitted into is notorious for getting hardened crud inside it, clean that really well and fit a new seal, inspect the piston for rust spots and chrome flaking as well, if any present replace that as well.
Stainless steel pistons are available to cure the rusting problem
Will do, thanks! Any preferred source for CB400 brake caliper seals and pistons?
Classichonda spares do a stainless piston and seal kit, cheaper to buy direct than ebay
Yeah, good shout Bryan, used them myself.
. Just be aware that, as somebody else said, when releasing the brake pressure the only returning movement is the seal regaining its original position, which is negligible. Once the whole ensemble is assembled, and on the bike, the movement of the pad/calliper is barely visible to the naked eye. Can't remember the clearance, it's in the workshop manual which is out on the garage at present, but I'm sure somebody with a better memory than me can help!!
0.15mm
I checked it both with excessive clearance and the workshop manual clearance. In both cases, after applying the brake/releasing it, there was zero clearance between the rotor and either pad. Even the smallest blade (.05mm) of a feeler gauge set could not be inserted.
Thats Honda-classics.co.uk near daventry, he does lots of stainless bits and special tools, even decent price sets of tappets caps
If you take the caliper hydraulic side off then hold it in your hand so your fingers are on the bare piston, now squeeze the brake just a tiny bit, you should feel the piston move back in when released, like a tiny heartbeat :)
This shows the seal is soft and chewy, with enough clear geometry in the groove to operate correctly. If it just moves out only, then the groove at least is not clean.
If you've not got this characteristic on any caliper really, the pads will always rub too much, possibly glaze too.
It's imperative the groove is fully cleaned to produce best operation. Lubricate with silicone grease (it's in the original Honda manuals) that groove and seal to keep it this way as long as possible. This largely stops water (road salt etc) getting into there and causing galvanic corrosion again, it is the only real weather sealing strategy of many caliper with single seal and no boot to protect them from water.
I have ordered: braided lines, a new seal and piston for the caliper, and two sets of pads to try, Brembo and Versah. The Master cylinder seems to operate perfectly so I wasn't planning to rebuild it but wonder if it might be a good idea? OTOH, "If it ain't broke don't fix it" is always something to consider... ::)
I was going to start disassembling the brake system today but decided to wait until all the parts get here so the bike isn't "out of service" any longer than it has to be.
I do a final check with any hand mastercylinder when it's all set up.
Crude but effective, squeeze it with both hands as far as it'll possibly go a few times, until it feels like everything is bending, really severe :o then hold a hand behind the twist grip and hit the ball end of the lever in multiple times to pulse the whole system in a controlled violence :)
During this the lever should repeatedly give the same travel, neither lengthening or pumping outward. All the seals working properly should give absolute consistency under this routine. Any real variables and you'd have to examine why that's the case.
Sounds severe, but properly puts far more elevated pressure through it than any normal use, and always verifying if there's any likely problem.
Final check, after that, roll the wheel to assess release, it should not bind at all after the above. Then ride it to see what ya got.
I do this with every front brake I work on.
Sounds like recipe for breaking levers!
"Sounds like recipe for breaking levers!"
And when would be a good time to find out if there's a failure point in a brake system ?
I'm reasonably confident that any lever I could get to fail with my hands alone I'd not want to be riding with :)
I work on many MTB hydraulic system too, would never want someone else to ride something I couldn't place absolute confidence in.
In all honesty I've never broken one like this. Leaking banjo, bleed closure etc detected that had given owners previous problems but couldn't be found by someone else working on them.
If you are using a nice soft rubber headed mallet that should not break the lever - I guess it depends how hard you strike the ball end.
Oops Ted, thanks as I now realise I didn't put critically the hit method :-[ just the palm of my hand to pulse the lever, no tools or weight required.
There, does that seem better ;D
If I used the Palm of my Hand like that I would have a massive red bruise for weeks! :'( :'( :'(
Better. 🙂
Better with hand. Not sure it's necessary though.
I think a stress test on the brake system is a very good idea, if it fails it fails in the right place not when you REALLY don't want it to be failing.
This morning I did the brake work; turns out that almost none of it was needed. :(
The 'old' brake fluid that I drained from the system looked like it had just come out of the container! The caliper looked good and had a new-looking SS piston. The groove for the seal did have some grunge in it so I cleaned that up. I installed a new seal, a new Honda brand piston (totally unnecessary - should have disassembled the caliper first before ordering parts) - and the new Vesrah pads. Then installed the new HEL lines/bled the brakes got a good, firm lever...just like it had before! ;) It is raining so I didn't have the opportunity to test the brakes though I ran the bike bike/forth in the community garage. In that minimal bit of testing I couldn't feel any difference at all. :( If the weather is better tomorrow I'll go out and put some miles/braking on the new pads. If there is no improvement, I'll install the Brembo carbon/ceramic pads and see how they work.
The one positive outcome is that the brake is releasing properly now; it appears that was the only thing I accomplished!
Make sure you bed the pads in properly, most people don't even know how to do this TBH, they just go out, hammer the brakes on and wonder why it's not as good as they expected. Especially true of bedding in ceramic pads, it's a fairly lengthy job TBH, I'll see if I can find the instructions on how to do it properly, came off the SBS website IIRC.
Clean the brake disc off with brake cleaner to remove any existing pad transfer material, a gentle rub with some fine wet and dry won't hurt either. Then take the bike out and do 15 gentle brakes from 30mph and then a 2 mile cool down followed by another 15 or so from around 45mph using moderate brake pressure followed by another 2 mile cool down run, then stop to see how the discs look. You should clearly see some pad transfer, it's a sort of blue/grey mist on the surface of the disc, then do 15-20 full on braking sessions from around 65-75mph, dropping the speed down really quickly but rolling off when around 10mph and then back up to speed later, followed by a 5 mile cool down run.
I've copied and pasted and adapted that from a post of mine on another forum, the method was advised by SBS on how to bed in ceramic pads but can also be used for other materials
Thank you! Weather permitting I'll do that tomorrow!
I'll echo the need to go through a bedding period / process, they have very little of their true performance straight after initial installation, and so difficult to judge tangible improvements or otherwise.
Ordinarily, you'll feel them improving as you go through running and preparation to then give assessment.
Additionally, modern brakes have so much spare capacity in torque they can impart, off the top initial potency of bite etc, that most wouldn't know they are not initially performing that well by using them at normal road speed. Many situations wouldn't tax them in any significant way and so you dont notice if they are anything in the way of lacking after pad change etc.
The older systems I feel that you'll definitely feel the difference as the pads and discs get a little more familiar with each other :)
Most disc aren't good immediately after initial cleaning with solvent, whatever their design and material spec.
Interestingly back in the 1960's my late father would always advise car owners not only to bed in new brakes but tyres as well.
Then again back then a new car had to be run in for the first 500 miles or so.
Drum brakes (extensive in that era) are significantly subjected to circular irregularities in surface of friction materials and shoe pivot point variables. Getting them all worn so they touch competently of good advice certainly.
Anyone hold the rear brake on while torquing the wheel spindle during wheel installation ? At least takes out any available variables in brake plate position to help as best possible the alignment on them.
Moto-X drum brakes of past era's are usually a bit wide toleranced when it comes to brake plate on spindoe location. Especially with twin lead design, often significantly improved by this tightening method to get both shoe working to maximum effect.
Standard procedure for old Brit bike drum brakes. Does make a difference.👍
Went out today to "bed in" the brakes per Odjob's post. The Results?
FANTASTIC! It is orders of magnitude better than previously and stops with authority now where it used to be "scary." Of course, since I changed pads, caliper piston and seal, and brake lines I can't say whether any/all of that contributed or was it just new pads/proper bedding. In any case, I am quite pleased with the brakes and with the help of folks on this site!!
As soon as I got back I let the bike cool a bit and proceeded with the next project - pulling/checking/adjusting the carbs. Pulled them off with no drama at all. I want to have them sorted/back on the bike for a ride on Friday. Hope I don't need any parts other than the various o-Rings. I have those and new carb screws from Nurse Julie.
Several big aerosols of carb cleaner or better still an ultrasonic cleaning bath
What pads were those in the end Mike?
Could you see evidence of the pad transfer on the surface of the disc BTW?
"Several big aerosols of carb cleaner or better still an ultrasonic cleaning bath"
Yes...Definitely will be buying a few cans of carb cleaner!!! Ultrasonic would be nice but don't have one and don't want to take the time to send them out.
"What pads were those in the end Mike?"
They were the Vesrah V series.
"Could you see evidence of the pad transfer on the surface of the disc BTW?"
Yes, as described in your earlier post.
I really appreciate your suggestions and that of everyone else on the forum! VERY IMPRESSIVE forum!!!
Certainly interesting to get a first hand perspective (yours mike) of before and after on a brake that's relatively unfamiliar to you.
From experience, the seal and how the piston moves freely, with the clean return when released, is the biggest shift in most calipers. All other things being equal, it'll shift most brakes from poor to decent operation at least, the other elements obviously all help, but that free movement is absolutely key to making good use of pads etc.
You can see this often on mot rollers for cars with compromised rear calipers, slight dragging (% illustrated on gauges) pads glazed resulting from this, low service and handbrake effectiveness % all cleared by having the calipers seals cleared and lubricated.
They seem such small differences, but priduce a whole trail of inefficiency within the brakes.
These 400 weren't that bad when new (no not a match for current new system) but stopped decently for example I think it's about 30 ft from 30 mph. Often recollection given nowadays would have you applying the brakes at maximum, then sailing on through a veritable time zone, only then to perform a U turn to come back from next week, and only went out to get a pint of milk ;D
They weren't that bad and, just as demonstrated here, can provide perfectly safe current performance.
Yes, the brake is perfectly fine now as far as I am concerned. :)
Good to hear and as mentioned before no need to settle for there not as good as modern brakes point of view. Reckon I also need to bed my pads in when my rebuild of the rebuild is done. Rd carbs I found this a very good read
https://www.vintagebikebuilder.com/cb550k-carb-rebuild-demonstration.html
Thought I'd add a bit more re brakes. Today, after installing/tweaking the carbs I went out and did carb testing and some more "brake-in" (NPI)...OK, yes, pun intended. The brakes are now quite good. They have excellent feel and do not lack power at all.
On modern vehicles I suspect the brakes are so overly-capable that breaking-in the pads doesn't really matter much. And I admit I have never "broken in" pads before. But I cannot adequately convey the difference between how the brakes functioned when I first rode this bike to how they function now after new pads/break in. A week ago they were scary bad; now I would call them good brakes!! Not "good for an old 1970's motorcycle," GOOD BRAKES period!
I don't think that my installing an OEM Honda piston with new seal, and a set of HEL brake lines is responsible for this improvement. I think the Vesrah pads were a notable improvement over what was in there but, more importantly, I believe the big factor was the break-in procedure that OddJob posted. :)
This, of course, is my new-guy observation based on ONE experience with ONE 1976 CB400. One experience does not count for anything in the statistical world. But I'd suggest that if a CB400 brakes are not very good, after first ensuring the mechanicals are functioning properly/adjusted correctly as per guidance on this site, try a set of Vesrah pads and break them in as per Oddjob's post.
Have been following this post with interest as my 550 front brake was pretty poor. Went out yesterday and followed procedure for breaking in. And a very noticeable difference even for pads that had been used, although not a lot of usage. And proof that there was some pad usage during procedure is the dreaded squeaky brakes are back! So next job chamfering pad edge. Happy days! 😊😊
It's important that any old pad transfer is removed before starting the bedding in process. It's like when Formula 1 cars lay a bed of rubber on the track, the track grips better. For pads it appears they work best when the bed is of the same material as the pads. So clean the disc with some brake cleaner and lightly sand with some fine wet and dry. It works for some reason.
I'm not 100% sure Mike that the pads are critical to this result, I've used quite a few different compounds on my 1300 and most were giving about the same results. It's also other factors that can come into play, organic pads for instance can fade with heavy usage and tend to produce lots of dust, sintered pads don't fade as badly and produce far less dust (as a rule) but the disc wear goes up appreciably. I've found Ceramic pads to be the best, almost no dust, so no cleaning the front wheel every few weeks, far less disc wear, don't seem to fade at all and best of all they give really good feel. My current setup seems really odd to me at present, it gives so much feedback I keep thinking they can't be stopping that well, whereas before when you pulled the lever the bike reacted so harshly, now I squeeze the lever and the bike just seems to glide to a stop in the same sort of distance. It's so good I keep thinking it can't be right.
I'd love someone to try a set of the Brembo ceramic pads and see what they think after bedding them in correctly, maybe this setup is the breakthrough on braking that the SOHC has been looking for for so long. Or maybe not, we won't know till someone tries.
Got to say the bedding in process is kinda boring, I found a loop of my estate was 1 mile, so I kept looping the estate doing braking stops every few hundred yards, then a full loop or loops trying not to use the brakes only the engine to slow down so I could cool the discs, then start again for the next step. I kept passing the same people, I'm not sure what they made of me going past every few minutes suddenly stopping every few hundred yards for no apparent reason.
Yes, I wouldn't make any real claims that the Vesrah pads would be any better than any other pad, just that they were much better than the pads that were in the caliper which were grooved and appears glazed. I don't understand the grooves since the rotor is perfectly smooth.
Grooves in a pad are usually for dispersal of water.
I have an engineered right hand fork leg hung up in the shed which has been machined to house a right hand disk conversion to twin disk. can't convince myself that I want to go the the trouble of the extra engineering that would be involved. having said that I had a twin disc front end on my 400/4 back in the 80's and I could do stoppies on that. also had both disks cross drilled which helped.
pastitpete
In doing some research for fueling on my 400 (different thread), I found an original road test from Cycle World of a 1977 CB400 four.
The 1977 Cycle World test showed the bike stopped from 60MPH in 135 feet. Now that's not fabulous by current standards but it isn't bad. Interestingly, that is the same stopping distance that Cycle World reported for a 2022 Honda CB1000R.
Frankly, I think the "common knowledge" that these bikes "always" had poor brakes may be internet fiction. Apparently, they had good brakes when they were new...well, as good as a 2022 Honda CB1000R anyway! :)
Prior to buying my first 400/4 I owned a 250 Matchless single with a drum front brake. Braking was scary on the matchbox to say the least, it really was ‘hit & (or) miss’. The disc brake on the 400/4 was a revelation, not in the ‘stoppie’ league but still really good........until it rained and then it was another story! The rain deflector fitted by Honda over the leading edge of the disc itself did nothing to help either and it was only following the development of EBC sintered pads that wet weather braking became acceptable on early disc braked motorcycles. Compared to a bog standard OEM drum brakes (forgetting the fancy Fontana and Robinson racing drum brakes) disc brakes were a league ahead in the 70’s.
