SOHC.co.uk Forums => CB350/400 => Topic started by: Matt_Harrington on September 05, 2023, 07:28:18 PM
Anyone have the size to hand?
The parts book has it as : (B.T6S) 96201-80000
Measured mine and it seems a strange size....
It is a strange size and genuine are not that expensive, just remember to use a tube to hit on the flange not the end
Contact Julie as i just filled up her stock draw with them ;)
Thanks. I'll put the old one back until I have time to make some s/steel ones - hence I was asking for the size.....
How are you going to make the internal check valve?
I have some larger threaded s/s ones and I was going to re-thread them - if that makes sense....
You're going to rethread the nipple stem or the swinging arm Matt?
Seems simpler to rethread the bolt rather than the nipple. At least then replacements are easy to find.
The originals are push in but i have drilled andctapped the bolt 6mm before now
The tread is 400 mate. Only screw type ;)
Sorry, never look at the header just read the posts!
Have you just awoken mate ;)
Been doin stupid hours due to idiots closing the M5 mate
Isn't that part just a normal size Matt? It's the same as the 550 swinging arm nipple and I'm sure I've replaced that with a stainless one before now. What thread pitch is it?
I can not even remember the last time i was on a Motorway. As you know Bryan, not to many in Lincolnshire ;)
Ken, it's taper thread. It maybe M6 x 1 but I will check later when I unearth my nipple box (that just sounds wrong!) I have some identical S/steel ones but the thread is bigger so I was just contemplating modifying one .....Anyway, the old one is back where it belongs!
Could you not just run a normal tap down the hole and make it like the stainless one you have?
Pretty sure you're right BTW, M6 x 1.00 sounds right.
I could but I didn't fancy getting swarf inside the arm. Anyway, biking/bikes curtailed for a while as I almost cut my thumb off on a table saw and I'm now feeling rather stupid at my carelessness and sporting a rather lrge bandage on my hand! :-[
Not Good!🥵🥵😳
Did you make up any new anglo saxon words?
Speedy recovery
I was remarkably calm considering the blood that was flowing! Even managed to drive myself to A&E.
All stitched up now....
Many years ago when removing rear wheel bearing from a triumph t140 after a liquid lunch my left thumb got trapped between the speedo drive flange on the hub(about 1/8 thick steel and a rapidly moving lump hammer, i proved you could get a 1970 3.0ltr capri round a right angle turn at 60mph with 4 people in it!
The downside nowadays is that as well as the nerves on the end of my thumb letting me feel what i touch so does the scar half way down tell me its the end of my thumb
My late Father-in-Law cut off his thumb & part of the adjacent two fingers when cutting up timber on his Petrol driven bench saw in the garden. At the time he was a Drayman for Allied Breweries - the hospital stitched the bits back on but his thumb was a sold fix as he lost the joint. About 6 /8 weeks later he was back at work! Back then he had no safety guards on his 40 year old saw.
Ooooh, sounds like a close shave Matt. That'll be throbbing later 😭😭😭😭
Sounds bad Matt hope it all heals up soon.
I recently gave away my Bosch Disc Cutter as it has always scared me when cutting Slabs & Pavers as it was impossible for me to hold it steady when I pulled the safety switch to ON, the torque was just too much for my aging arms. I was always afraid of cutting off a toe! I bought it almost 30 years ago to cut my garage roof tiles with so it owed me nowt.
M6 x 1 (45deg) grease nipples seem to fit AOK - found a stash in my box and tried one out.....
