SOHC.co.uk Forums => CB350/400 => Topic started by: Athame57 on September 11, 2023, 05:39:55 PM
Title: Bike isn't recharging the battery
Post by: Athame57 on September 11, 2023, 05:39:55 PM
My bike isn't recharging the battery, is the rectifier or alternator the most likely culprit?
Title: Re: Bike isn't recharging the battery
Post by: McCabe-Thiele (Ted) on September 11, 2023, 06:45:57 PM
I think you can add regulator into the mix as well.
I would start by checking all the plug in connectors especially anything you might have disturbed recently such as if you have had the engine right side engine  cover off to check the rear sprocket or similar.
The wires where they come out of the alternator housing and pass eventually to the connector plug.
I assume the battery is good.
I personally would then check the voltage output at the regulator - instructions are in most manuals.
After that someone here will know about the remainder - in my brief experience it can be something simple.
Post by: Oddjob on September 11, 2023, 09:13:26 PM
What Ted said. Most times it's either a broken wire, a trapped wire or corrosion on the connectors, especially the block connectors under the l/h panel.
Reports of the wires going into the stator coil breaking off recently, check the above first, if no joy then remove the generator and check all connections inside that cover.
Post by: Bryanj on September 11, 2023, 10:24:49 PM
95% of time bad connectors, 4% of time broken wire rest bad parts
Post by: Athame57 on September 23, 2023, 10:14:51 AM
Well, did the bike shop get it right, my battery isn't going flat after all!  ;)
