SOHC.co.uk Forums => CB350/400 => Topic started by: Matt_Harrington on November 17, 2023, 11:23:02 AM
Left over in the tray from when the 400 was stripped is the part below:
[attach=1]
Anyone know where it should live? Of course the PO could have fitted it but it does look commercially made....
I've never seen that on a 400/4 Matt. It looks like an earth wire of some sort.
Unless it's a home made replacement earth wire that goes from the starter solenoid to the battery? All the ones I have ever seen though are black and have a bigger terminal on one end to fit the battery.
Could be a homemade earth wire for inside the headlamp.
Looks like an added extra earth wire to me as well,
oddly enough I have a similar one left over from my 500 build except it's the same cable diameter as the battery earth.
Mmm, strange. I'll put it to one side as earth is all OK and all electrics work fine! Hey ho!
