SOHC.co.uk Forums => CB500/550 => Topic started by: DerekB on March 13, 2016, 06:51:34 PM
I have a 1971 Honda CB500. I'm new to the rebuilding world, but I love tinkering in the garage. So I removed the LH crankcase cover to my bike the other day, no problems getting it off. But when I reinstalled it, the hand lever cable was not engaging the clutch to allow me to shift gears. I never adjusted anything inside the cover, but I didn't do something right when assembling. When I pull the lever everything seems to be working inside the cover. I did have several (maybe 6) small 1/4" orings that fell out of the cover, broken, when I removed it. I'm not sure where they go. My manual doesn't spec them out anywhere. Any ideas how I may have mis-assembled the cover?
have you lost the ball bearing that fits in the operating mechanism, it bears against the pushrod.
no the ball bearing is still in place. after installation, do I need to readjust something? does the pushrod slide in and out when squeezing the clutch handle?
Thank you for all the excellent advice. Like I said previously, there were maybe 5-6 small broken o-rings that fell out of the cover when I removed it. Are these for the grooves that are on the push rod? Or somewhere else? I currently did not replace any of them since I was unaware of where they came from. My maintenance manual does not spec them out anywhere.
Only O rings inside that cover are behind the oil pump and cannot fall out, also they are 15mm.
Sounds like somebody has put them in there to cover up a problem. As oddjob said check the ball bearing and pushrod, adjustment procedure is in the manual
I disassembled the entire assembly today and gave it a good cleaning and new grease. Reassembled and adjustment and the clutch lever now works. The lever has always been fairly tight to squeeze and I figured out why when reassembling the parts. I don't think all the parts are stock inside the cover for the clutch actuation. I noticed that while squeezing the clutch lever, when the internal part is rotating it hits on the sheetmetal bracket inside making the clutch lever hard to compress. I didn't modify the bracket yet to give clearance, but its on the list now.
Thanks again to for the help!
Derek
That sheet metal contraption is to stop excess damage if the chain breaks but can get bent and cause problems
