SOHC.co.uk Forums => CB500/550 => Topic started by: Erny on April 28, 2019, 07:51:07 PM
Hand on my speedo gauge is shaking in some speeds, wants to clean and then re-lubricate speedo gear on the front wheel.
But wondering what lubricant shall I use? Thinking on some grease that is verz soft anf does not turn into liquid...
Any recommendations?
Note: the same I want to do on my CB750K K7
Lithium grease
Same as deltarider, lithium general purpose grease as used in car wheel bearings.
If it is only doing it at some speeds are you sure it's not the cable.
As above a naff cable can cause the clocks to do funny things.
Any damage or slight resistance swap it for a new one.
Lubrication done, shaking stayed... so next is cable to swap. Will order cable next time I make bigger order to DSS or CMS
Thanks!
Thanks!
Wemoto do a nice range in cables.
I had to replace my tacho cable. And one of theirs fitted well .And looked well made.
