SOHC.co.uk Forums => CB350/400 => Topic started by: waffey on November 22, 2020, 01:24:07 PM
Hi, me again!
I thought I would clean the front brake caliper bracket up. I cant take it apart. I don't think its threaded or is it. Is there a trick to parting the two pieces?
thanks in advance
Hold the bottom bit in the vice, heat the top bit and turn it. The O rings will need replacing. Before you take it apart, make sure there is no up and down movement in the arm.
thanks nurse Julie, I'll give it go. I didn't want to force it earlier.
