General => New Member Introductions => Topic started by: Andy1976 on July 16, 2008, 11:16:08 PM
Hi everyone I'm Andy from wakefield West Yorkshire.I'm restoring a CB750F1. I have had it recently rebored and I am starting to put the engine back together now that I have managed to find replacement pistons. Iam hoping to have it running for the Lotherton Hall show at the end of the month(27th july). This is my first restoration project and I will post some pictures as soon as I've sussed out how to do it.
See you soon, Andy
P.S. how co I check that the colour of my bike is original? It's blue and I don't think it's right.
hello there
brand new here myself, got to say so far been very friendly and helpful
probably a better way of doing it but try this , pop your reg mark in and should give you original or at least registered colour
thanks mike
http://www.vehiclelicence.gov.uk/EvlPortalApp/application;JSESSIONID_EvlPortalApp=L15PJzZGcJGP6QbFvs0bmJrtJ9vdQhwZVNfvHphH5gTlkbcHmkJx!-1306707376!-1168852789?origin=vnav_bar.jsp&event=bea.portal.framework.internal.refresh&pageid=Vehicle+Enquiry
Hi Andy and welcome, my 1976 F1 was originally red but is now black due to me fitting and F2 tank and seat, the only colours that I have seen an F1 in are red and yellow, but there was a blue F2 so it may be an F2 tank. You can probably tell by the tank stripes the F1 has pin stripes rather that the big flash on the F2, and all F1's had grey side panels.
Den
Hi Mike + Den. I've tried the link that you posted and it is registered blue. On my tank there are no stripes at all, so it might have been re sprayed at some point. Also the side panels are the same colour as the tank. I would post a picture for you to look at but I don't know how to do it. Thanks, Andy ??? ??? ???
Hi Andy, here's a link to a very standard red F1.
http://www.vintagebike.co.uk/Bike%20Directories/Honda%20Bikes/pages/Honda-CB750F1-76.htm
Den
Go here (http://forums.sohc4.net/index.php?topic=14605.msg93296#msg93296) for instructions as to how to post pictures.
One day I'll copy the post over here!
Nobody can tell you what the original colour was, not even Honda, so as long as you stay to a produced colour you will be OK. At least you can get to RS in Barnsley to get the paint! Post the frame number and i will let you know the colour options but do it in the specific bike post not here.
Hi Brian, i have posted the frame number in the CB750 pages of the forum under "blue coloured F1". I hope this helps, many thanks, Andy
Thats a strange one as I remember the F1 in 76 being Yellow or Red(as per the ID book). The 2 colours i gave on your other post were US only, is yours an import?
I think my bike my be an import but I'm not 100% sure. According to the log book it was first registered in the UK on 01/04/1976. Are there any significnt differences between imported and UK models?
Just the obvious ones.
Higher bars
Huge rear light
Running lights? (Not sure about this for 76 though)
Show us a picture or two and we'll soon have it sorted out!
this is my bike.(http://i345.photobucket.com/albums/p363/andy-1976/CB750pics/260708mis044.jpg)
(http://i345.photobucket.com/albums/p363/andy-1976/CB750pics/260708mis047.jpg)
Is it just me or is that exhaust a bit low to the ground. Its a BSM from good old DS
(http://i345.photobucket.com/albums/p363/andy-1976/CB750pics/260708mis046-1.jpg)
I think I've sussed out posting pictures, cheers Steve :D
Couple of points:
- Exhaust does look a bit low - don't drive up too many kerbs!
- What's that passenger grab rail screwed onto?
- Who pinched your ignition switch?
- Throttle cables should go inside of headlamp "ear"
Other than that - looks like a UK model - just repainted at some time.
Oh, your tax has expired too.
That exhaust is too damnn low to the ground and all the visible bits say its a uk/european one, Definately Non Standard paint
The grab rail is bolted on to the plastic seat hump.I'm going to take this off as it's not very secure. My key snapped off in the ignititon switch and I can't get the broken piece out, so I'll have to replace it.
What would you recommend I do with re painting it, should I go for candy sapphire blue which Brianj pointed out or should I be going for a UK spec colour?
Unless you want to enter competitions, it doesn't really matter. Go with what you like.
Get a set of prpoer decals though as that will put the finishing toch on it. They're not cheap but will bring back the original look.
Hi Andy.
Not to far away from you....in Doncaster.
Tom
Ay up Thos, I was in Donny last week, Bawtry I think. I was Pricing up some plastering for an old dear.
Anywhere near you? closest place round here for bikers to get togther is Squires cafe bar in sherburn. meet up for a brew sometime(if I can get the flamin thing running)?
Andy
Hi Andy,
Bawtry's not to far from me, I live about ten min walk from the dome at Dony. Just waiting for the spokes & nipples to be chromed so I can get the back wheel put back to gether again,
tom
