SOHC.co.uk Forums => Project Board => Topic started by: Valentinik on January 09, 2016, 10:51:13 PM
Some will have seen my introduction post but if you haven't, First of all, this is the first bike i've owned and its a big learning experience more than anything for me, i've had numerous cars and I'm currently build a turbo westfield but bikes are something i have never worked on. So please excuse what some may feel are stupid questions.
Today i went and collected a new project. Its a 1977 CB550 K3, it looks like someone has changed the forks to super dream items as well as the wheels. Im hoping to find some good used items, refurbish them and replace them. As can be seen from the pictures, some bits are missing and its not in too good a state but something i thought was suitable to work on.
I went and collected the bike from leominster this afternoon. To pay my wife back for coming with me i had to take her out to dinner so wasn't able to start until we got back (she wasn't pleased).
Here it is before it was put in the garage:
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/1EAD4074-7A6E-4DA2-A9DF-E8A86ECAFFD2_zpssuuaxhhg.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/1EAD4074-7A6E-4DA2-A9DF-E8A86ECAFFD2_zpssuuaxhhg.jpg.html)
I've removed the seat, tank and exhaust and just had a look at what exactly is missing and what i need to do:
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/7ADD6C69-FA92-4FB5-8F8C-CABA3835D3BA_zpsdknwzhug.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/7ADD6C69-FA92-4FB5-8F8C-CABA3835D3BA_zpsdknwzhug.jpg.html)
One thing I'm not sure of what it is/where it is meant to fit is this:
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/BB9D0268-FDD8-4B09-9821-16361656E0A1_zpsixkxzmec.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/BB9D0268-FDD8-4B09-9821-16361656E0A1_zpsixkxzmec.jpg.html)
Could anyone give me a pointer on what it is?
Mike
Brake light switch that attaches to the rear brake lever
If you haven't already got hold of them I'd suggest getting a copy of the Parts List and Workshop Manual from here:
http://www.sohc.co.uk/index.php/topic,8884.0.html
Personally I have found a parts List to be far more useful than its name might suggest.
if you need a bracket and spring I have new ones I was going to put on ebay.
The brake light switch attaches to a bracket, on the 500 and I'm fairly sure the 550F it's a bracket welded to the frame, on the 550K however it went into a bracket which was separate and attached to the upper rear engine bolt, probably why it's loose as on the 500 and 550F you wouldn't really need to remove it. It's missing a long thin spring which goes through the hole in the pin you can see protruding from the switch.
If the carbs are missing I'd fit the carbs off either the 500 or the 550F as the 550K carbs were much different and TBH are pretty pants in comparison. You'd also need the airbox to match but it's a worthwhile change as the 550K carbs really are that bad.
Good advice from oddjob about the carbs.But u also have to change the intake manifolds on the back of the head.Your intakes wont line up with the older style carbs
Thanks everyone, its all really useful information to me, i've learnt so much already. Il keep an eye out for some carbs, the frame is the first thing I'm going to be working on though. So i've got plenty of time to gather the bits together.
I made a little bit of progress this morning. Both wheels are off, the engine is out and i've taken a look at the forks. The chrome seems to be pretty rusty and I'm not a fan of the wheels, so i may see if i can source a set of original forks and spoked wheels.
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/F172873F-9878-418F-A939-DCA2661D044B_zpsfuzhuudg.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/F172873F-9878-418F-A939-DCA2661D044B_zpsfuzhuudg.jpg.html)
Before i took the engine out though i wanted to check it turns over as i didnt know what state it was in. The good news was it turned over quite freely. The less pleasing news was when i drained the oil, 2 litres of water came out before the oil.
As you can see from the picture theres a bit of rust on the camshaft and tops of the valves but I'm hoping its still useable. Im planning on a full engine rebuild anyway.
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/7D28F68B-0FB2-47CE-8671-D3C0AD1F033A_zpsms6ypavc.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/7D28F68B-0FB2-47CE-8671-D3C0AD1F033A_zpsms6ypavc.jpg.html)
Mike
Once you get inside the engine, check the journal bearings under that camshaft, have you got a rocker cover? Also check the valves are seated and not bent, Hopefully the water will not have been in there too long. I would think the twin disk setup and superdream front forks should be easy to re home.
Thanks guys, Is there a specific year of carbs/inlet I would be looking for?
Unfortunately I don't have the rocker cover. I think that is the reason for all of the water ingress, it seems like it has been left outside for a while.
Are the rockers and cover specific to the 550, or would a 500 set work if i can get them?
As I'm not going to get around to the engine build yet, i wondered if it would benefit at all to fill the engine with some fresh oil that i've got spare?
Mike
http://www.ebay.co.uk/ulk/itm/311516677219
These are the carbs you want!
Im not personally recommending this set btw
That's great thank you. Il keep a look out for them.
Before I remove the wiring loom I'd like to test that everything works. However the ignition switch is faulty ( it's held together with a cable tie). Is there a brand of switch that's ok to use? Or should I go with a genuine Honda item?
This will do u Mike!
https://www.davidsilverspares.co.uk/CB550K3/part_28995/
Brilliant, ordered along with a spark plug spanner. I've decided to strip the engine down now and clean all the parts. Hopefully to try to protect them from any further damage. Just incase the water hadn't been in there too long.
Mike
My Ignition switch arrived today. So i hooked a battery up and tested everything. Everything seems to work, the only issue i can see if that the rear light is constantly on. The light switch has no effect on its operation, when the switch is moved the light flickers ever so slightly but nothing more.
Is there anything i could look at that may be causing it?
Mike
If its a Canadian Bike (or perhaps a US Bike supplied to certain States) the lights are often linked to the ignition.....i.e. Ignition On = Lights On.
I had a Suzuki GT500 which I bought new in 1976 when I lived in Canada and that always ran the lights as soon as the Ignition was switched on........I had no problems with that set up but if I remember correctly it was the law at the time in Canada.
Worth looking into......maybe a UK market switch might solve the issue.
Thanks, that thought did cross my mind. Il take a look. When the switch is unplugged the light also stays on, i don't know if this makes any difference?
Mike
Sorry i didnt phrase it very well. The tail light goes out when the ignition is turned off, but it come straight on when the key is turned.
I presumed it should only come on when the light switch is used? Or am i mistaken?
Mike
I haven't got any lights on in the headlamp. I've now disconnected all of the plugs in the headlamp and when the ignition is switched on the tail light still illuminates. So the connection must be elsewhere. I've attached a picture of the frame plate and headlamp switch
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/84E091DA-B0D6-4D2C-9942-7DA726B5D29F_zpskbsic92n.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/84E091DA-B0D6-4D2C-9942-7DA726B5D29F_zpskbsic92n.jpg.html)
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/65F7D81C-BB52-4396-B928-67C697DCC656_zpslfkdcux9.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/65F7D81C-BB52-4396-B928-67C697DCC656_zpslfkdcux9.jpg.html)
Mike
It could be that a previous owner had a break in the loom somewhere, and rather than sort it properly has bodged a new wire or supply to the tail light, which is live all the time the ignition is on, with no way of switching it off ( seen it done a few times over the years) If it is an issue to you, do a thorough inspection of the entire loom and all it's connectors, looking for any odd/unusual looking bits of wire or strange connectors like the dreaded scotchlocks!
Sent from my X5 using Tapatalk
Thanks for the info both, I checked the fuse box, it looks very clean, no corrosion. The only time the light goes off is when this fuse is removed:
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/C4071C97-1A54-4D03-BA30-A29622DEEB12_zpswkre8ztg.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/C4071C97-1A54-4D03-BA30-A29622DEEB12_zpswkre8ztg.jpg.html)
If either of the other fuses are removed the light stay on.
I then stripped all the tape off the loom and found no wires spliced that shouldn't have been. The only issue i found is the positive feed from the solenoid to the mulitplug that feeds the main loom, the red 12v+ wire was quite corroded and broke while i was examining it. I may replace these with modern waterproof connectors in the seat pan I'm going to fabricate.
I doubt this would be causing the problem with the light. To sum up, the light operates with nothing plugged in, only the main loom connector to the solenoid and the ignition switch, in the on position, not P.
Mike
I made a start on stripping the engine down to try and limit any damage from any water. Tonight I got the head and cylinder removed, so far I'm pretty pleased with what i've seen. The bores look to be pretty good with no visible scoring or lips, so I'm hoping i can use it without a rebore. The only bit of damaged i've found so far is a slight mark on one of the pistons.
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/IMG_1063_zpslauzhdgs.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/IMG_1063_zpslauzhdgs.jpg.html)
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/IMG_1065_zpsvl2lxdhi.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/IMG_1065_zpsvl2lxdhi.jpg.html)
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/IMG_1064_zpswyqzrhsf.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/IMG_1064_zpswyqzrhsf.jpg.html)
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/IMG_1066_zpsdo35a61j.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/IMG_1066_zpsdo35a61j.jpg.html)
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/IMG_1067_zpskijtua3l.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/IMG_1067_zpskijtua3l.jpg.html)
You can see the damage in the circle. After i've got it all stripped down and inspected i want to get the cases painted/powdercoated, is there a preferable way to clean the crankcase. Vapour blasting, etc?
Mike
The logbook for the bike arrived today. Which pleased me as the seller never had it when i purchased the bike, against my better judgement i bought it anyway (after doing a HPI).
Anyway, i made a little progress tonight. I never mention when i started the topic that I'd like to go with a brat style with the bike. I know its not to some peoples taste but i've always liked that style of bike.
With that in mind, i started on removing some of the brackets from the frame that i won't need. Side panel mounts, battery tray mount,etc.
Before
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/498C3E06-FEB4-4409-9382-B7786AB3A35E_zpskffd2t2z.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/498C3E06-FEB4-4409-9382-B7786AB3A35E_zpskffd2t2z.jpg.html)
After
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/A5A197B8-9717-4D8D-BF84-2D0A05C35C4C_zpsgwdgioed.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/A5A197B8-9717-4D8D-BF84-2D0A05C35C4C_zpsgwdgioed.jpg.html)
I only got one side done as it was getting late but hopefully tomorrow i will finish the other side off. Im not sure yet if I'm going to cut the rear of the frame slightly and weld an upswept hoop in like this:
(http://i.imgur.com/Mkzqp3y.jpg)
Or just remove the bridging section between the 2 sides weld a brace in to mount the seat to.
Mike
I got the brackets cut off the other side this evening:
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/958F0C19-64C2-450B-9AFF-2101834D012E_zpsdsffqynd.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/958F0C19-64C2-450B-9AFF-2101834D012E_zpsdsffqynd.jpg.html)
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/8752E381-BB6E-4B5C-8B46-C9CF89049A6B_zps4n1ho5s0.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/8752E381-BB6E-4B5C-8B46-C9CF89049A6B_zps4n1ho5s0.jpg.html)
I've just got a few smaller sections to tidy up and then i can cut the bridge at the back. I also got an impact screwdriver and undid all the bolts from the clutch housing, so i can carry on with stripping the engine.
A question: I've read a lot of topics on keeping the standard airbox and filter. Seeing as i don't have the airbox and the carbs i buy will need rebuilding/rejetting to suit the engine. Other than having to rejet the carbs which i would have to do anyway is there any other issue with using pod filters instead of the standard airbox?
Mike
Mike
Lumpy idle
I finished off stripping the engine down tonight. The only sign of damage i've found from the water is a small amount of rust on the primary drive gear on the crankshaft. I haven't attempted to clean it up yet but I'm hoping il be able to.
Pistons and top crankcase removed:
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/9FFA5756-18FB-4974-A35F-233A6CD9CE59_zpsz9j05rsy.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/9FFA5756-18FB-4974-A35F-233A6CD9CE59_zpsz9j05rsy.jpg.html)
Bottom crankcase, I've just got the main shells and primary shaft bearing to remove
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/DAC146D8-2295-4116-AE3C-008FFBE98323_zpsxeseyqsl.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/DAC146D8-2295-4116-AE3C-008FFBE98323_zpsxeseyqsl.jpg.html)
Top crankcase, just the shift drum to remove
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/CE08CE48-37AA-4C87-961D-13C71BAAC620_zpsmcu2udhs.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/CE08CE48-37AA-4C87-961D-13C71BAAC620_zpsmcu2udhs.jpg.html)
Mike
Unless you have a problem with gears leave the drum in there but as you are that far down at least a primary chain is a good idea, you can just see the marks where it has started to touch the oil gallery
Blimey Bryan, you must have eyes like a hawk.
Have to to see through these glasses mate!! but just know where to look
Thanks for the input chaps, i will replace the primary chain and cam chain whilst the engine is apart.
Will this gasket set be suitable? and will it include all of the seals i need or will these be extra?
https://www.davidsilverspares.co.uk/CB550K3/part_29005/
(https://www.davidsilverspares.co.uk/CB550K3/part_29005/)
Mike
http://www.ebay.co.uk/itm/Honda-CB550-oil-Seal-Kit-Made-in-Japan-90000-374-000-/121875335555?hash=item1c60560983:g:oQ4AAOSwDk5T5sMS
Is an oil seal kit that comes with the rubber blanking plug, even from Australia its the cheapest one
Thanks for the info guys, i'l get the parts ordered.
Mike
Tonight i got the rear seat frame mocked up in position. I just need to work out a way out finishing off the ends of the frame underneath the hoop.
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/0065E8A9-1803-454E-8BBA-B689602D7FB6_zps2up8zlkj.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/0065E8A9-1803-454E-8BBA-B689602D7FB6_zps2up8zlkj.jpg.html)
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/637A44DF-52DC-4214-A38F-C5D609AD4DD2_zpsxryj3kva.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/637A44DF-52DC-4214-A38F-C5D609AD4DD2_zpsxryj3kva.jpg.html)
The wheel is only there to check positioning. Im having a set of new spoked wheels made with black powder coated rims and stainless spokes with the hubs i've got.
Mike
I spent a few hours on the frame this afternoon and got it finished.
Rear hoop and seat mounts welded in:
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/0AECC215-AB6A-4EB5-855D-351F571A3AFA_zpsoy3d5avp.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/0AECC215-AB6A-4EB5-855D-351F571A3AFA_zpsoy3d5avp.jpg.html)
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/C22E09EE-1DAD-4E1A-B5F0-0B211EABF832_zpsaop8hmti.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/C22E09EE-1DAD-4E1A-B5F0-0B211EABF832_zpsaop8hmti.jpg.html)
I also made a small battery box and welded a bracket underneath the swing arm to mount it. I just need to weld the aluminium box up
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/25DD7984-C225-4DC1-835B-A629A97B187D_zpsqgfzhwfx.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/25DD7984-C225-4DC1-835B-A629A97B187D_zpsqgfzhwfx.jpg.html)
Mike
I made the aluminium panel for the seat tonight and mounted it to the brackets i welded on the frame. The bolts are only temporary.
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/IMG_2475_zpspryfzgyk.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/IMG_2475_zpspryfzgyk.jpg.html)
Mike
With reference to this post oddjob made about fitting some 500 carbs. Im looking at buying some but i wondered what year 500 bike would i need to be looking for and what the model of the carb is?
Mike
Great thank you.
I got my crankcases back from being soda blasted and finished cleaning them up. Tonight I put in the replacement primary shaft bearing. I just need to find a replacement oil guide as the one i've got isn't great.
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/F3E04C9F-F622-45DB-9C85-2EEF915FEA16_zpslnpplihx.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/F3E04C9F-F622-45DB-9C85-2EEF915FEA16_zpslnpplihx.jpg.html)
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/D1FCCDD2-10BE-4891-BCB1-E0B35AB5DC58_zpsmpcnsogo.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/D1FCCDD2-10BE-4891-BCB1-E0B35AB5DC58_zpsmpcnsogo.jpg.html)
Mike
Looking at various costs for rebuilding my 400/4 motor and soda blasting of interest. Who did you use and rough cost if you dont mind.
Tim
I used a local company to me called Sutton soda blasting, in Sutton Coldfield. I had the top and bottom crankcases done and paid £40, but i blocked all the holes off. It would have been more if i had sent it bare.
http://www.suttonsodablasting.co.uk
Mike
That seems pretty good to me. I was in semi shock having got a quote at the weekend for £250-300 to vapour blast full motor. Thought it was extracting the michael at that!
That does seem a little excessive, i know his vapour blasting is more than just soda blasting but i think that only came out at around £120.
A question about the primary shaft installation if someone wouldn't mind answering. In the manual it states this:
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/Screen%20Shot%202016-02-24%20at%2021.16.39_zps3vqlgifz.png) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/Screen%20Shot%202016-02-24%20at%2021.16.39_zps3vqlgifz.png.html)
I can't see any markings on the starting gear and clutch to indicate how to position it. Is the position of them important and if so, how do i go about aligning them?
Mike
It isnt important, BUT ignore the boolk and build everything into the top half of the crankcase thaen after case assembly you can refit the primary shaft by holding the starter/primary gear through the sump hole. This way makes it a lot easier to get the selectors etc to line up
Thanks both, that's really useful. My next question was going to be about how to align the gear selectors.
I've left the selectors assembled on the drum but I can't see any mention in the manual about how to align the gear and selectors in the right place. Is there a picture of the gears in the correct position I may have missed somewhere?
Make sure you also renew the primary shaft dampers along with the primary chain, it will last a lot longer if you do and will also be far quieter as they tend to go hard and lose their damping ability as a result.
The primary chain was already on my list as it had started eating its way into the crankcase, but i'l add the dampers as well.
brilliant thank you.
Mike
On the 550 only one selector is on the drum the other two pivot on a seperate shaft with pegs locating in the drum grooves, again in the manual
Progress is slow due to a lack of time and money at the moment but tonight i got half an hour to start building the top crankcase up. I got the shift drum and shaft installed and starter gear (not sure if this is the correct term for this?)
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/108EF53E-B7D9-49D3-B91C-0CDF4F85AA2D_zpsynmz6qus.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/108EF53E-B7D9-49D3-B91C-0CDF4F85AA2D_zpsynmz6qus.jpg.html)
Mike
Tonight I got everything in place and checked all gears engage thanks to the advice from Bryanj and Oddjob.
It selects all 5 gears and each one seems to select smoothly.
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/06E3004E-D8C0-425D-ADB4-159FF35A41A7_zpsfrckgnan.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/06E3004E-D8C0-425D-ADB4-159FF35A41A7_zpsfrckgnan.jpg.html)
Thanks, I double checked the roller bearings were located over the pins as at first it didn't sit in position, but they sit down correctly now. By setrings, do you mean the half moon bearing fitted in the bearing groove at one end of either shaft?
Thanks for the pointer on the oil seals, i had presumed they would have been fitted after the cases were joined so it has saved me making the mistake.
Mike
Other things have stopped progress for a while but i found a set of forks on eBay complete with triple trees. They're in very good condition, the trees will need powdercoating and i'l replace the oil and seals but they're fantastic for £52 posted.
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/DC1B1674-A1E5-445F-8E33-AF76CEC78DC4_zpsvuci3xur.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/DC1B1674-A1E5-445F-8E33-AF76CEC78DC4_zpsvuci3xur.jpg.html)
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/9188303F-0065-45EE-8D04-33AB2EEF7F16_zpsu8n1glj1.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/9188303F-0065-45EE-8D04-33AB2EEF7F16_zpsu8n1glj1.jpg.html)
Mike
No progress for a while apart from collecting a few smaller parts, but I'm just about to order some bits to complete the engine rebuild.
Apart from a full gasket set, primary chain and primary dampers and cam chain, is there any other parts i should look at replacing?
I recall i've seen somewhere an alternative part for the primary chain and maybe the cam chain swell that may be cheaper than DS, could someone point me in the direction of where to find one if i wasn't imagining it?
Mike
Oil seal kit springs to mind. Piston rings and so on.
Cam chains from DID are not expensive, around the £25 mark ;)
Thanks Trigger.
No progress pictures but i got the frame stripped down completely and took it to to be blasted and powder coated as well as the swingarm and yoke. They're quite busy at the moment so it may be a couple of weeks before its done.
On the way back i stopped into the local Main dealer and got the primary rubbers and a few circlips that needed replacing as well as some new shock bushes and oil seals. DS didnt have all of the parts in stock, so i have't got all of the bits to rebuild the engine at the moment.
Mike
The larger bits came back from the powder coaters today. Im really pleased with the finish, its 99% perfect and only cost £96 all in.
I found a prime position to start the build:
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/9DE98986-4AB9-4B1A-8AE9-C67B852E2889_zpsvrf9s81m.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/9DE98986-4AB9-4B1A-8AE9-C67B852E2889_zpsvrf9s81m.jpg.html)
The wife didnt have the same opinion on where the build should continue so it was relegated to the garage. (it made it longer than i expected)
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/000A4B6F-7BB0-4D8B-8415-967AC542531A_zpstvkwaheb.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/000A4B6F-7BB0-4D8B-8415-967AC542531A_zpstvkwaheb.jpg.html)
A few close up pictures:
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/6E0CAE91-B87A-4C80-AB3F-30D4D68F3463_zpsww8facnr.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/6E0CAE91-B87A-4C80-AB3F-30D4D68F3463_zpsww8facnr.jpg.html)
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/D24D0B4F-1A3C-45AC-8D9F-6974AE5C768C_zpswzzxiqbq.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/D24D0B4F-1A3C-45AC-8D9F-6974AE5C768C_zpswzzxiqbq.jpg.html)
Mike
A question before i start building the frame up. Which is the preferred method to fit the engine.
Fit the engine to the frame with an engine crane. Or position the engine on the floor on its side, and fit the frame around the engine?
Mike
With the CB750 definitely put the engine on its side and lower the frame onto the engine, I'm pretty sure the same method is best for the 550.
Thanks Mark, thats what i will go with.
A question RE: swingarm installation.
When installed and the pivot bolt torqued, should the swingarm fall under its own weight or stay in position?
I have torqued the bolt to 38lb ft and now it is torqued up, when released the swing arm stays in position and doesn't fall. Is this correct?
Mike
As long as it is easy to move by hand it will be OK, if you have to put effort into moving it no
Thanks guys.
Oddjob, yes i've had blown out and cleaned the swing arm before i did anything else. The chain guard brackets have been removed as i don't intend on using the chain guard.
Thats good to know about the engine, is it possible then to fit the cylinder barrel with the bottom end installed in the frame, or is it better to fit it before fitting the engine to the frame?
Listen to Oddjob. He's the man...
Thanks, I think i'l fit it the barrel before i fit it into the frame and then fit the head, clutch etc when the engine is mounted.
Following Oddjob's advice of fitting the engine to the frame partially assembled I started assembling the first few bits onto the frame.
My tapered steering bearings arrived today so I've now got the yokes installed. I fitted the swingarm during the week. This is how it stands at the moment:
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/B790CC6E-F7CB-4E56-B1ED-B65DD3693CD0_zpshhe1rcex.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/B790CC6E-F7CB-4E56-B1ED-B65DD3693CD0_zpshhe1rcex.jpg.html)
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/DAFBB7A7-6E50-4157-B758-3347BBA86797_zpsplgsbbqf.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/DAFBB7A7-6E50-4157-B758-3347BBA86797_zpsplgsbbqf.jpg.html)
My next job is to work out a way to hold the rear hub so i can remove the wheel bearing retainer.
Mike
Is it easier to wait until the wheel is built and then change the bearing Mike ?, I don't know if the 550 is the same as the 750 but on the 750 the retaining ring is centre dotted to lock it in position, I took a fine drill and drilled out the centre dots , I'm not sure if there's another way but someone will say if there is .
Thanks Mark, i wanted to strip it down so i can have the parts blasted and powder coated so it needed to be done before the wheel is assembled. I've now got it stripped down and the bearings removed, ended up holding in a vice between 2 pieces of aluminium to protect it. I made a tool to remove the retainer ring.
Mike
My primary and cam chains came from DS today so tonight I put the crank into the top half of the crankcase. Hopefully during the weekend I can fit the bottom case and get it sealed up.
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/40EFCA0D-C962-4917-97A4-8DC93B63CE8B_zpsguj4tbas.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/40EFCA0D-C962-4917-97A4-8DC93B63CE8B_zpsguj4tbas.jpg.html)
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/0D6B41F0-7C42-4950-8DA1-14D5F3C05A34_zpsjx62vqrv.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/0D6B41F0-7C42-4950-8DA1-14D5F3C05A34_zpsjx62vqrv.jpg.html)
I have some loctite si5980 sealant, will this be suitable for sealing the cases together?
If not, I need to buy some hondabond to seal the cases, is there a specific type/strength which is the correct one to use?
Me thinks that SI5980 is just silicone sealant, you want something that does not dry.
Hondabond or Hylomar is cheaper, it needs to be a thin layer or it will squeeze out in to your engine. I always put it on the case and scrap it with a plastic card, leaving just a tacky surface.
Thanks trigger, I've got some blue hylomar so will go with that if it's suitable.
Mike
Don't forget to put the primary gear inside the chain first
Thanks for the pointers both, the kickstart is already assembled in the bottom case. I have however forgotten to order the cap for the clutch shaft.
The local main dealer can't get them in stock and they are a week special order from DS so il have to wait for it to arrive before I can assemble the cases. >:(
My oil seal arrived today so I got on with building the engine cases back up.
I got both cases mounted together and the primary installed:
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/4256EB29-EC84-4CB1-876B-A460D5D845F4_zpsmwlwurr5.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/4256EB29-EC84-4CB1-876B-A460D5D845F4_zpsmwlwurr5.jpg.html)
I have also installed the gear shift:
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/C901D1E7-48C6-469C-A867-91A578E021E6_zpsz6nv5jck.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/C901D1E7-48C6-469C-A867-91A578E021E6_zpsz6nv5jck.jpg.html)
A concern I have though is, there seem to be 2 small issues with the casting either side of the shaft, shown in this picture. Is this something I need to be concerned about?
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/D1A7572F-C719-4A9B-B9CF-D102DDC034FF_zpsnan1yv1j.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/D1A7572F-C719-4A9B-B9CF-D102DDC034FF_zpsnan1yv1j.jpg.html)
Mike
I seem to remember that the line on the bearing should be horizontal with the joint line so are you sure it was on the locating peg properly?
Thanks Bryan, I did look at that and double checked the pin was located and that everything moves as it should. I've also got a picture of it like this before I stripped it down:
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/IMG_2360_zpszerhaaxk.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/IMG_2360_zpszerhaaxk.jpg.html)
Mike
Thanks oddjob.
Over the weekend I got the engine bits painted and baked in my home made oven.
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/E728162A-D22E-42D6-87F1-EBC1AE6B043E_zpsrmgniplp.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/E728162A-D22E-42D6-87F1-EBC1AE6B043E_zpsrmgniplp.jpg.html)
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/97200290-D7F4-4728-AE86-57D6017D95BB_zpsgernvtrj.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/97200290-D7F4-4728-AE86-57D6017D95BB_zpsgernvtrj.jpg.html)
I also collected the remainder of the parts from powdercoat
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/864F2CCE-E94D-42B5-829E-06D0675047F0_zps9v89ujwv.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/864F2CCE-E94D-42B5-829E-06D0675047F0_zps9v89ujwv.jpg.html)
I've also ordered the tyres for the wheels so hopefully will drop the wheels off to be built with new spokes at the weekend.
Thanks, I think I did like the look of the bolt head being the same colour as the case in this instance. For the less (torque) critical bolts I was planning on using stainless cap heads where I can. (Covers,engine mounts,etc).
You are correct, the gear shaft seal was missing when I took the picture but it's been installed now. Along with fitting the Pistons to the rods.
I took the tank to a friend today who is the paint shop manager for a very large dustbin lorry manufacturer as he offered to paint the tank for me.
I try to do as much of the work myself and to learn new skills as I go. However, the equipment he's got to use will undoubtedly give a better result than me doing the job myself.
The colour I've chosen may not be to everyone's taste but I'm hoping it will suit the style I'm going for.
The tyres and new wheel bearing arrived today. I got on with pressing the bearings in so I can take the wheels to be built up at the weekend.
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/16A3C0B2-2DB0-48E6-86EA-C4BC29EB61B7_zpsoxrqkp1n.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/16A3C0B2-2DB0-48E6-86EA-C4BC29EB61B7_zpsoxrqkp1n.jpg.html)
It's looking good what colour spokes you going for
Thanks, the spokes will be satin black also.
It's probably a bit too much black for some tastes but I've never really been a fan of shiny things like chrome, stainless etc. So I'm trying to limit the amount used to bolt heads etc.
Mike
I have black rims/spokes on my mountain bike, but with red anodised nipples, looks mint, just a thought!.
Thanks mark, the only other colour I'd have gone for was to match the tank but I don't think the colour I've chosen is available.
I started rebuilding the forks today. Got the new seals installed and everything In place but have A question.
What torque should the 8mm Allen head oil lock bolt at the bottom of the fork be tightened to? And should thread lock be used on it?
I did take a look in the factory manual but the bolt descriptions weren't clear to me.
Mike
Just do it up tight is enough and only use threadlock if you want it to be a swine to change seals again BUT do make sure the copper washer is in good nick
Thanks Bryan, I will get some new washers fitted before they are installed.
Spent some time over the weekend, getting the forks on and the partially built up engine I'm the frame. I can get on with finishing the engine build off now.
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/55637C6D-FBB3-403A-A4CA-208B93322F73_zpsxfixobon.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/55637C6D-FBB3-403A-A4CA-208B93322F73_zpsxfixobon.jpg.html)
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/704FA4E5-90F4-4DAF-9B50-9F55A48848CF_zps36bdbpd6.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/704FA4E5-90F4-4DAF-9B50-9F55A48848CF_zps36bdbpd6.jpg.html)
Mike
A question, I have a new gasket for the clutch cover, do I need to put and hylomar on this gasket or should it be fitted dry?
Mike
No sealant needed, although some people smear the gasket with grease, helps stop it sticking and tearing if you need to do any further work inside.
That's a great tip, thank you. :)
Mike
I got my tank back today. Im really pleased, it looks flawless. The colour may not be to some peoples taste but its exactly what I wanted.
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/19030787-8E47-40E3-9779-3C34EC97E4B9_zps8nvw6tto.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/19030787-8E47-40E3-9779-3C34EC97E4B9_zps8nvw6tto.jpg.html)
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/92896B1C-3C05-4FA1-AE2B-6E7C86E6E8F1_zpszozmnujc.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/92896B1C-3C05-4FA1-AE2B-6E7C86E6E8F1_zpszozmnujc.jpg.html)
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/A11E0795-8C93-442C-B367-87C9E187B9F3_zpsc8qt80o5.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/A11E0795-8C93-442C-B367-87C9E187B9F3_zpsc8qt80o5.jpg.html)
Mike
I got the cylinder head installed tonight along with the cam.
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/6D8C696E-7B36-4BAF-89CA-26B0B92B50E2_zpsrpr8dody.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/6D8C696E-7B36-4BAF-89CA-26B0B92B50E2_zpsrpr8dody.jpg.html)
I had planned on fitting the rocker cover. When I removed the head I noticed the 6 rubber blanking caps had been installed with some sort of clear sealant. Do they need any sealant fitted or should they just sit in place?
Mike.
New rubbers should not need sealant but pattern ones sometimes need A VERY SMALL AMMOUNT.
DO READ THE MANUAL CAREFULLY BEFORE FITTING THE COVER or you WILL bend valves
Thank you Bryan.
I must admit I forgot to order new seals up to this point. Is it possible to re-use them or is it wise to replace them?
Mike.
Depends how lucky you feel, 80% of the time you can reuse the other 20% it leaks more oil than the Torrey Canyon
Its not as old as i am and yes the RAF did bomb it to set the oil on fire but repeatedly missed!!!
I got the wheels back from the wheel builders today so spent the evening reasembling them and fitting them.
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/41CCE62E-4A42-44CB-92C4-ADFC798DA895_zpswbh4owsx.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/41CCE62E-4A42-44CB-92C4-ADFC798DA895_zpswbh4owsx.jpg.html)
A question, I couldn't see in the manual ( I may be being stupid) the torque spec for the bolt behind the steering stem bolt. Can anyone tell me what the spec is?
This one:
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/4B6328F6-479B-4798-A0F6-A2385992A7BA_zpsl8p1v9gf.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/4B6328F6-479B-4798-A0F6-A2385992A7BA_zpsl8p1v9gf.jpg.html)
Mike
Its a pinch bolt, pinch it up but, not too tight ;)
Thanks, will do :D
What's happening with this build, or am I missing it somewhere else? Enjoying the read.
Hi, No youre not missing it anywhere else. I've started on the wiring, i have positioned the starter solenoid and had some power cables made up. Unfortunately thats as far as i have got due to working on my car project and the wife wanting me to do DIY :(
This is a picture i took a few weeks back when i was having a tidy up in the garage. This was the first time it had touched the floor with its wheels on, and the first time i had sat on it.
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/5747134E-A54D-4BB5-84AA-D3B740BA72A5_zpssbntrukn.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/5747134E-A54D-4BB5-84AA-D3B740BA72A5_zpssbntrukn.jpg.html)
Mike
Small update, i've now got the rocker cover fitted, i just need to source some tappet covers as it only came with 2 and they aren't in the best condition.
(http://i1356.photobucket.com/albums/q739/S2-Roadster/CB550/E3EE16BC-AE47-4BBB-AB4C-83EDFFF9FB02_zpsievbplpc.jpg) (http://s1356.photobucket.com/user/S2-Roadster/media/CB550/E3EE16BC-AE47-4BBB-AB4C-83EDFFF9FB02_zpsievbplpc.jpg.html)
Mike
8)
I've not had much time to work on the bike since my last update due to moving house earlier in the year so my time has been filled with diy, gardening and lots less interesting things than getting this finish.
Earlier in the year i bought a set of cb500 carbs which i've stripped down to replace all of the serviceable parts and powder coat some pieces.
Over the last couple of days i've ordered a few bits to hopefully get the bike started for the first time (since i stripped it down). I've now fitted the oil pump along with the left had engine cover. Today some tappet caps and new ignition coils arrived. Ive got the coils fitted, just need to sort the spark plug leads out.
The carb bits and tappet caps should go to the powdercoaters within the next few weeks and then i can hopefully make a start on getting it started.
Mike
While waiting for the rest of my ignition system to arrive i test fitted the stop tail light that i made. The housing is made from aluminium and the lamp itself is held in with stainless mesh and a stainless circlip.
